08-03-2007, 05:18 PM
#61
Re: Chevy Lean **updated 9/19/06**
I took my truck to the local Chevy dealer and he said his tech measured the lean and came up with a half inch which is in specs. I have been a carpenter foreman for the last 24 years and I do believe I know how to read a tape measure. And yes the spot where the rear tires were sitting was level, I poured the floor. I have read where you should give the truck at lease 3000 miles to break in the suspension. If after that, the truck still leans, I will take it back to a different dealer.
08-04-2007, 06:10 PM
#62
If you don't want to mess with the dealer, just buy the $15 leaf spring spacer and fix it yourself.
08-05-2007, 12:23 PM
#63
I think I will take your advice Nick
08-05-2007, 05:13 PM
#64
You're gonna need the new u-bolts too, your factory ones won't have enough extra room.
08-07-2007, 08:14 PM
#65
Will do thanks
08-13-2007, 08:09 PM
#66
I've got a 2002 Silverado that sits about 1" low on the left front. I've read all of the fixes, but does anyone know what causes the problem to start with?
08-14-2007, 12:30 AM
#67
bigjohn
a lot of hard right turns  J/k
i think most people attribute the problem to the extra weight on the drivers side
 .....SOLD.........,(moment of silence for my dodge) wtf was i thinking, back with a 02 sierra 4x4
09-14-2007, 12:56 PM
#68
Originally Posted by poboychevy
the problem is in the left rear of the truck, next time you see a transport truck look at the way the chevy,s are tie down. i work for a chevy dealership as an auto body tech and a few years ago we got paid by gm to correct the tweak on the frame. the problem is these truck are tied down on the front, and only on the left rear, and they actually twist the frame down a bit from the backside of the cab.
That is also why they are always out of alignment from the get go.
2003 Chevrolet Silveraod
1500HD Crew Cab 2WD
09-19-2007, 06:52 PM
#69
Parabellum
Mine sags/leans on the rear left... Pisses me off
1997 K1500-5.7L-Duals-AEM Brute force-Upgraded ign sys.- Detroit Trutrac, COOPER STT 285, 3:42's DVD player HU, KX1200.1, 2 kicker 10" L7's, Polk Components, TYC HID's, Shiftkit Built Trny
2001 Camaro Z28 lotsa goodies-Mid 12's.
10-20-2007, 10:17 AM
#70
Does anyone notice a difference depending on the amount of fuel in the tank being that it is on the driver side?
11-04-2007, 10:28 PM
#71
The fuel does not affect the lean. I have tracked my heights and the empty vs. full affects both left and right side the same.
1995 Z28 M6, 313 rwhp/323 rwtq - 58mm TB, LT4 HOT kit, 30lb SVOs, stock exhaust
2002 Silverado RCSB, 5.3L, 285 rwhp/312 rwtq - Volant, 80mm TB, ASP Pulley, Dynatech LT, FM50series, efans, !TM, FLT Level4, Boze 20", BFG KDWs, Baer brakes
Vehicles tuned by Jeff "The Milkman" Creech
11-14-2007, 08:22 PM
#72
I just replaced both rear springs on my Silverado becauase the driver's side had broken the middle leaf right behind the spring pad, and it's still 1 1/4" lower on that side in the rear and about 1/2" lower on the driver's front. One of these days, I'll take it to a body shop and have them check out the frame.
2000 Silverado ECSB 2WD, 5.3L, Automatic, 3:42 gears; MSD plug wires, Bilstien HD shocks, otherwise stock and mostly factory original.
12-22-2007, 08:28 PM
#73
If any of you guy's have your truck dropped it is easy to correct. I have a 3/5 drop on my 05 sierra (ground force) if you have adjustable rear shackles just set the passenger on the next lowest stting and it pulls the driver front up a bit and lowers the passenger rear a bit which actually makes everything even out. by pulling up the driver front it lowers the passenger front a bit and by lowering the passenger rear it pulls up the driver rear a bit. no driving issued whatsover.
2005 GMC sierra, radix with 8.5 boost 408 rwhp and 459 rwtq
02-06-2008, 11:34 PM
#74
i have an 03 GMC Sierra halfton, and i have the "chevy lean" problem. I had spacers put in, but the left side still looks a little lower. Does anyone else have this problem or know what to do???
02-17-2008, 08:11 PM
#75
Re: Chevy Lean
Seems like every one of the trucks have this problem.
I believe I read somewhere that the dealer has 1/2"-3/4" front coil spacers to replace the original thin no-squeek pad under the bottom of the coil spring. Same for the rear leaf springs.
Any auto parts house spacer installed in-between the coils would probably affect the travel.
A good GM parts guy should be able to answer this.
My '03 1500 RCSB (with trailering package) height varies 1/2"-3/4" lower at the left rear with a full tank.
Low tank it's dead even at the rear wheel openings.
05-28-2008, 02:03 PM
#76
Advance Auto parts has a replacement spring that should help the front leaning problem. Part no. FCS20222S.
10-13-2008, 04:25 PM
#77
$ILVERADO
My old 99 sierra leaned
2wd also left side
you can tell sorta from this pic
but alot more from the back
07 Silverado / Magnaflow / Airaid / AR rims / Debagded / Lift coming soon i hope
02-22-2009, 08:27 PM
#78
jb that truck looks photoshopped in yo sig lol
2000 chevy silverado 1500 Z71
6" RCX LIFT
35X13.50X20 MICKEY THOMPSON BAJA ATZ
20" MOTO METAL 951
COLD AIR INTAKE
STRAIGHT PIPE WITH CATS
02-22-2009, 08:30 PM
#79
 for jb truck in sig
6" RCX LIFT
20" MOTO METAL 951
COLD AIR INTAKE
08-19-2009, 01:16 PM
#80
Just checked Advanced's website. The part number is now 60150 for the alternate spring from Moog.
2000 1500 5.3 2WD RCLB. Stock. For Now.
| Thread Tools |
| Display Modes |
Linear Mode
