05-11-2006, 11:31 PM
daytime running lights
Newb this site. Have just received a 96 K1500. Has daytime running lights. Did a search with no results.
1. Is this a permanent thing?
2. can I shut them off?
3. If so, How?
Reason: double post
05-12-2006, 05:08 PM
#2
Re: daytime running lights
05-12-2006, 05:18 PM
#3
Soul Devourer
Gaytime running lights. I hate those things.
05-13-2006, 01:31 AM
#4
Howdy: I read thru all the post and got hung up on OBS and NBS.
Since my first pickup was a 66 Chevy, My second a 77 and now this 96, Spanning 40 years. I'm not up on GM/Chev. Technology or abreviations.
Been a Jeep man since 86, but they quit making pickups some time ago. AND I have a thing for Chevy Pickups, you'll notice.
Bear with me..... Is the Dome overide button that thang under the light switch for the head and dash lights that pushes in and out and does nothing I can see?
Also I checked the owners manual and they say,"There it is".... Dang if it ain't!!!!
Thanks for the help!
05-13-2006, 01:47 AM
#5
Work as hard as you play
I got tired of driving with only one because the other one blew and replacing them all the time. Took out the only good one left shook it till it broke reinstalled it and problem solved. If I need driving lights I turn the switch to on.
05-13-2006, 09:58 AM
#6
what i do is click my e-brake in one time and it will work
Lovin my hoe's lol
05-13-2006, 11:41 PM
#7
Thanks everyone I have some directions to go now. I'm hoping I understand the E-brake trick?? Do you kick it down a notch or set it and then release it after startup or such?
05-13-2006, 11:54 PM
#8
crimson tide bowtie ride
i was asked by the guard at the local AF base to turn mine off pulling up (so as not to blind them) but had to explain that i couldn't.  i'll have to try the E-brake trick. good info bro.
05-14-2006, 01:26 PM
#9
The dome overide keep your dome lights from coming on when you open your door. On some OBS 96-98 i think if you push it in and out like 5 times it does something i read it in a owners manual.
It might cut off your day time lamps. can't remeber for sure
05-14-2006, 08:14 PM
#10
cracker
Its so easy for a 96-98 obs I cant belive none of you know this.
Open drivers door-pull cover off of fuse box on side of dash-look at cover-find the letters DRL on the covers list-go to that spot on the fuse box-remove fuse-put cover back on-start the truck-walk to the front of the truck-look at headlamps.WOW!!!!!
Long story short,PULL THE DRL FUSE.
P.S.99-02 press dome light button on-off 2 times in a row NOT 5 times.This will shut off DRL.
05-14-2006, 08:22 PM
#11
Yeh, it's as easy as taht :P
05-14-2006, 09:23 PM
#12
and there ya' have it! lol
i still like the E-brake idea for temporary solution
R.I.P.totaled by 18yo daughter 1997 4 door Tahoe 4X4 all options except rear A/C and heated seats, 2.5 inch duals. almost stock....FOR NOW
1995 tahoe 2 door 4x4 bone stockROLLLLLLLLLTIDE!!!
05-14-2006, 09:41 PM
#13
WOW!!!! Thanks everyone! Works great. I did pull the fuse too. I don't intend to put fog lights on but want to put Deer screamers on. Those little plastic gizmos...??
I know this is probably simple but what is "obs" and "nbs" with the chebby line?
Well Thanks again for the help.
Caller
05-14-2006, 10:06 PM
#14
Caller[/QUOTE]
O.B.S = Old Body Style 1999 & down
N.B.S = New Body Style 2000 & up
05-14-2006, 11:09 PM
#15
OK, Thanks for the answer. I'm going to check out some pix of both to get familiar with them.
09-20-2006, 11:40 PM
#16
3. If so, How?
you can shut them off by either the fuse or your light switch on your dash board. but merely just turning the switch to the left to where you see the O symble. that just temperaraly does it but it does cut them off until you turn your vehicle on the next time.
09-21-2006, 12:11 AM
#17
Lifelong Chevy Man
On the '96 I don't think you can use the light switch to turn the DRLs off. Dad always just clicks his parking brake down one notch if he wants them off on his '96.
On my '01 1500 HD, I can push the dome override button 4 times fast and there will be one chime and the result will be no DRLs AND ALSO it disables the auto-on headlights, which like to turn on in the middle of the day in my carport. when the key is turned off and then back on, this defaults back to normal and has to be done again.
My buddy's '06 1500 he can turn the light switch left and it springs back and the DRLs stay off until the key is turned off & on again.
Me, I don't mind them because I never have to look at them, so why do I care if they are on or off?
Kinda like the ugly orange clearance lights on the top of my cab... I don't like them much but I don't have to look at them while I'm driving downthe road, so I don't really mind 'em.
- Russ
09-21-2006, 12:42 AM
#18
Either pull the DRL fuse, take out the DRL bulbs or
check out http://www.lightsout.org
| Thread Tools |
| Display Modes |
Linear Mode
