Old 10-13-2006, 01:49 PM   #181
cgerace19
Member ID: 56382
Re: Finding Out If Your Vehicle Has A Recall Is Very Easy
thanx
Old 10-15-2006, 03:18 AM   #182
tekthrawn
'97 Yukon
tekthrawn's Avatar
Member ID: 56470
Heres my VIN for 97 Kon
1GKEK13R9VJ761907
Thanks!
97 GMC Yukon... No mods yet
Helper Monkey on a 72 Camaro Bracket Racer (See Gallery)
Old 10-15-2006, 09:40 AM   #183
GetMore
Member ID: 28812
Some questions on mine: 1GCHK24U71E346346
I've got an ABS sensor acting up, and my fuel gauge occasionally drops to E, along with a change in the tone of the fuel pump.
Do I have any recalls? Do I just need to clean/replace the hub/sensor and the fuel sender assy?
Thanks!
2001 Silverado 2500HD 4x4, 6.0/4L80E
Stock/tow vehicle
Old 10-15-2006, 10:16 AM   #184
ff92
Member ID: 51365
Hello Triton. Could you run 2GCEK19TX21219865, it's a 2002 ECSB 4x4 Silverado, and verify an ABS sensor problem. Thanks for your time.
Old 10-15-2006, 01:20 PM   #185
willy victor
Member ID: 52412
Hello Triton
I have all ready had my tailgate straps replaced under the recall, my question is, the replacements are all ready showing signs of corrsion. What is my recourse. Thanks in advance.
Willy
Old 10-16-2006, 05:39 AM   #186
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
tekthrawn-no recall
Old 10-16-2006, 05:41 AM   #187
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
getmore--as far as the fuel guage goes--get another fuel tank guage sending unit
no recalls on your vehicle---need tests run for abs problem to see what it is---
Old 10-16-2006, 05:48 AM   #188
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
ff92--since your vehicle is in canada, you do have a recall for abs system---ck with local dealer for appointment
Old 10-16-2006, 05:50 AM   #189
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
willy--is corrosion on outside of cables or inside---the actual cable is stainless and should not rust--if you are referring to the metal parts that attach the cable, they are still the same as the old ones--they will show corrosion but the cable is the important part and they will not rust
Old 10-16-2006, 06:49 AM   #190
73deville
Status:
Posts: n/a
Unhappy Re: Finding Out If Your Vehicle Has A Recall Is Very Easy
Hi
Could you please also check for me whether if there is a recall on my !997 Tahoe 4door 4wd, it kind of lost power and pull very bad. Had a leaking exhaust/down pipe but now fixed this afternoon and no sign of a sllipping trany. All seems alright but have no pulling power at all cost. Maybe if there is a recall perhaps it might help me to regain power.
Vin # 1GNEK13R5VJ418806
Thanking you in advance.
BB
Old 10-16-2006, 03:07 PM   #191
ff92
Member ID: 51365
Great work Triton, I'll get in touch with the dealer. Thank you!
Old 10-17-2006, 09:14 AM   #192
ADub
Member ID: 38888
1GCEC19R4TE233374
Thanks
Old 10-17-2006, 05:25 PM   #193
hornsfan10609
Registered Pimp!
hornsfan10609's Avatar
Member ID: 53300
Hey Triton, Thanks for doing this by the way. My truck's VIN is 1GCDC14Z9MZ2072 and i have no idea if it has ever been taken to the dealership ever in the past 16 years so this is greatly appreciated.
91 RCSB C1500 4.3 4L60
09 Ford Mustang Bullitt #5998
94 Ford Mustang SVT Cobra SOLD 9/4/08
Old 10-18-2006, 09:41 AM   #194
sbw
Member ID: 54620
Hello Triton. Thanks for all your effort. I would like you to check two VIN's for me.
1GNDS13S132307451
2GCEC19T511181943
Old 10-18-2006, 11:40 AM   #195
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
73deville, ADub, and sbw----no recalls
hornsfan--please ck vin number again and reply---not enough characters listed
Old 10-18-2006, 08:11 PM   #196
hornsfan10609
Registered Pimp!
Member ID: 53300
Sorry about that , just typed it too fast the real VIN is 1GCDC14Z9MZ207236. Thanks again.
Old 10-19-2006, 03:20 AM   #197
73deville
Status:
Posts: n/a
Hi Trtion20
Thaks very much my friend for yuor answer. Your guys are the Angels on my shoulders. Thanks again.
Ephraim.
Old 10-19-2006, 05:35 AM   #198
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
horns--- no recall
Old 10-19-2006, 12:54 PM   #199
MASTER Brian
Member ID: 56888
I am pretty sure I've checked these already, but just in case..
1999 - 3GNFK16RXXG106887 - Any history would be cool also.
1992 - 1GNEC16K9NJ316789
1992 - 1GCEC14K3NZ211680
Thanks for your troubles.
Old 10-19-2006, 01:59 PM   #200
TRITON20
Premium Member #40
PAINTPEELER
Member ID: 50599
master---first 2 vehicles--no recalls
last one has a recall for door cylinder freeze up---from a long time ago---contact nearest dealer and make appointment--tell them recall # 94011
