Old 09-11-2006, 05:30 AM   #81
PAINTPEELER
Re: Finding Out If Your Vehicle Has A Recall Is Very Easy
LOFFEN---first vin # does not come up--is this an old vehicle--not enough digits in vin #---second vehicle has no recalls
e-5---your vehicle is clean
VA2500hd--recall 05037--second row center safety belt--dealer will take second row center seat belt out of the loop and sew it shut--something about the way it fits different sized people that is not safe or helpful in a wreck----take to dealer--should take about 45 min.
derrangle-- 2825984 is the first vin and it has recall #04007-tailgate strap replacements due--second vin is clean---take first vehicle to dealer to have repair done--take about 15-20 min.
TRITON20 is offline
Old 09-11-2006, 03:42 PM   #82
Va2500HD's Avatar
Thanks alot Triton20, I really appreciate you looking that up for me. You are doing alot of folks on here a great service. I know it has to take up alot of time for you to do this. Again THANKS. John
Va2500HD is offline
Old 09-12-2006, 02:57 AM   #83
jtfrog's Avatar
Are there any recalls on 01 seat belts that lock up. If I fart my belts will lock up and are very hard to get free
Diablo tune
Corvette servo
Free Framboost
Belltech 2/3 lowering kit
Slam-Air rear bags by AIR-LIFT
Throttle body bypass
Auto Command Remote Start
jtfrog is offline
Old 09-12-2006, 04:25 AM   #84
Loffen's Avatar
Ops
Sorry,can you please try 3GNGK26U91G192148
Thanks
Espen
Loffen is offline
Old 09-12-2006, 05:23 AM   #85
PAINTPEELER
loffen---recall# 04094--Front Wheel Speed Sensoe Corrosion (canada Only)----need to ck with your local dealer on this one--it may not be done outside Canada since your vehicle was distributed by GM Canada---contact local dealer
TRITON20 is offline
Old 09-12-2006, 07:24 AM   #86
Here is my VIN 2GCEC19T221273240, Thanks for checking
2002, 1500 ECSB,Debadged, Leveled,Magnaflow Catback exhaust
cleangreenchevy is offline
Old 09-12-2006, 08:34 AM   #87
Supporting Member
JohnRXL's Avatar
Could u check this VIN#1GMDV23LX5D272376 for S.B. and re-calls?
05 Pontiac SV6
Thanks
JohnRXL is offline
Old 09-12-2006, 11:32 AM   #88
PAINTPEELER
CLEANGREEN--free and clear
johnrxl--no recalls--as far as s/b, they are listed by concern--i could pull up numerous s/b applying to your vehicle, but these are only tips for technicians and most of the times not problems for vehicles
TRITON20 is offline
Old 09-12-2006, 12:04 PM   #89
All That Is Man
LostBoy's Avatar
Will you check mine?
2GCEK19R2T1195843
I believe I was lied to by a dealership saying they took care of my wiper motor board.
Thanks!
LostBoy is offline
Old 09-12-2006, 01:14 PM   #90
Triton20,
Thanks for checking.
Old 09-12-2006, 02:52 PM   #91
Supporting Member
JohnRXL's Avatar
Thanks for checking!
Could I get a copy of the S.B. please and thanks
I could give u my e-mail address if u want to send it that way.
JohnRXL is offline
Old 09-12-2006, 04:11 PM   #92
PAINTPEELER
2 PROBLEMS WITH THAT---
1-what s/b are you refering too
2-- each and every one is copyrighted so i can not just copy and send along--they are meant for GM techs at GM dealerships only
what i can do, if you can give me a specific concern or complaint on the vehcile, i can ck to see if there are any service bulletins pertaining to it and then give you an over view of what is contained in the bulletin---
without going into detail john, there is a legal matter with copying and then sending these bulletins out without consent from GM-each and every tsb that come out from GM has the copyright info at the bottom of each and every page--and trust me the boys at GM do watch forums such as this from time to time
so tell me what concern you have, and i will try to help you with it
TRITON20 is offline
Old 09-12-2006, 04:17 PM   #93
PAINTPEELER
LOST BOY----shows recall was done in Aug 03 at 172k miles
TRITON20 is offline
Old 09-13-2006, 12:41 PM   #94
All That Is Man
LostBoy's Avatar
Thanks! Are there any others open, and were there any recalls on mine pertaining to the fuel pump/system?
Also - The intermittent setting is all over the place and the wiper motor just does goofy stuff in general - any chance I can have the previous dealership's work checked & verified? Needless to say they screwed me around enough to make me question everything they've done, and this wouldn't be the 1st thing they were "less than honest" about.
LostBoy is offline
Old 09-13-2006, 08:19 PM   #95
i just bought a 97 c2500. i would imagine everything has already been done but i thought i would check for sure. the vin is 1gcgc29r6ve169601.
i also wanted t ask if a dealership could tell me what came standard on my truck and the options installed. basically all the info on the window sticker.
thanks
rr
redrader is offline
Old 09-14-2006, 05:52 AM   #96
PAINTPEELER
REDRADER---ck that vin # again--does not come up and that would be very odd for a 97 model--please ck the vin again for me
lostboy---no, the recall had to do with w/wiper and washer pulse control module replacement--very common for those circuit boards to go bad--usually dealer installed another board and then put a fine bead of silicone on cover when reattaching it to seal it off---most of the time when they come in, and the wipers dont work, there is a bad soldier spot on the board--we replace the board of corse but i have 2 spares for my truck where i fixed the soldier connection--i just hope one of them works when i need it to------if i were you, i would just get another circuit board--they are not much at all and takes about 15 min. to install
TRITON20 is offline
Old 09-14-2006, 10:32 AM   #97
All That Is Man
LostBoy's Avatar
Thanks TRITON20 - I'd suggest maybe this thread should be a sticky, but I think then you'd have more #'s to check than you'd know what to do with! Thanks again for taking the time to offer this help!
LostBoy is offline
Old 09-14-2006, 06:22 PM   #98
1GCGC29R6VF169601.
Try it now. I mistook the F for an E.
Thanks.
RR
redrader is offline
Old 09-14-2006, 06:45 PM   #99
serial #1GCEK19R5TE155254 can you check this one please
jaychevy is offline
Old 09-14-2006, 07:17 PM   #100
Cheyenne Man
GMMonster's Avatar
My truck's VIN is 1GCDC14K3ME101312
Check it out for me please.
GMMonster is offline
