08-22-2006, 11:22 AM
PAINTPEELER
Finding Out If Your Vehicle Has A Recall Is Very Easy
if people want to post their vin # here on the board, i will run those #'s through GM at work to see if anyone has outstanding recalls and also give a little description of them
keep in mind, vin #'s over 10 yrs old may no longer be in gm's data base
sorry to say that i am not doing this anymore, but others who work at dealerships are carrying on this tradition... still post your vins
08-22-2006, 11:59 AM
#2
yukoner
Re: Finding Out If Your Vehicle Has A Recall Is Very Easy
do you only check if theres a recall?? can you check if my trucks been in an accident before?? its a 95 yukon and i bought it in 2000. for some reason i think its a lemon
08-22-2006, 12:17 PM
#3
PAINTPEELER
sorry---all i can do is run for recalls, in service dates, any warranty left through GM, things like that---i can not ck for damage/flood/accidents, things like that---
i was just thinking that some of the posts i have seen here, have sounded like recalls we have done in the past and just trying to help other members save money and time if possible
08-22-2006, 01:44 PM
#4
PAINTPEELER
somebody sent me a message but i can not view it here at work due to restrictions with internet service and work---so plese post your comment or suggestion or question here so i can see it please---thanks
even if you are telling me to  or  or even  plese post it here
08-22-2006, 01:48 PM
#5
"she likes it that way"
Hey triton, my VIN is 2GCEK19TX11289512 i'm the one having fuel problems. i PM'd you but i guess you can't get it.
01 Z71MODS!!3in. Perf. accesories body lift,Ford keys,2in. rear blocks,17x10 rubicon Quakes,35x12.50 TRXUS a/t's,k&n intake,painted,bumper cap,matching chevy emblem,2x8in. amp'd bazookas
08-22-2006, 02:43 PM
#6
PAINTPEELER
only recall on this vehicle was for replacement of tailgate cables--completed 06/17/2005 recall number was 04007
the recall i was thinking about covered 00-01 yukons and suburbs.....if you get a pump from GM, your pump will have updated wiring in it--you will need to get body side connector and splice it in to get it too work--dont forget, depending on dealership, electric fuel pumps have lifetime warranty---the recall was because of wiring getting too hot and then making bad connections at tank causing stalling with no restart to fuel guage reading very erratically
trucks have same set-up but they did not get recalled
08-23-2006, 12:57 PM
#7
Can you check mine?
1GCHC24U61E334394
Can you tell me what service has been done on it?
Thank you!
2007 Silverado Classic LBZ CCLB
Home of the 18 point U-Turn.
08-23-2006, 01:25 PM
#8
PAINTPEELER
you have recall #04007--tailgate straps replacement---should take dealer about 20 min. to replace and is free of charge--have your cables broken before? if so and you hace reciept from dealership where you bought replacements, you may be entitled to get that money back
as fas as what has been done to the vehicle, there has never been a warranty claim for repair filed with GM---sorry cant tell you anything else about service history
08-23-2006, 03:23 PM
#9
Smokin' Tires
Can you check mine?
1GTEC14K9NE524417
08-23-2006, 03:42 PM
#10
PAINTPEELER
KOLTRAIN--either incorrect vin# or it is an older vehicle that has been deleted from GM's data base--which means no recall and maybe 12-15 yrs old
chrisk1500--i cant read e-mails and pm's at work---post it here on this thread so i can see it
08-23-2006, 04:38 PM
#11
Here is my VIN.
The truck might be too old though....
2GCEK19S8R1234057
Thanks for your time!
07.5 LMM DMAX 2500 HD, ext cab, 4x4
08-23-2006, 04:41 PM
#12
PAINTPEELER
no recall on your canadian diesel truck outstanding
thanks for asking
08-23-2006, 04:45 PM
#13
Smokin' Tires
Might be to old,92 GMC C1500 SLE?
08-23-2006, 04:48 PM
#14
PAINTPEELER
most likely since it has nothing outstanding, it may have already been dropped--usually nothing before 92-93 can be viewed anymore---have ck'd several late 80"s and none are in system anymore and even a few other 91-92 models and only found one 92 model still in system
08-23-2006, 04:49 PM
#15
thanks for asking
Thanks!
08-23-2006, 05:58 PM
#16
4x4
Would appreciate it if you could check mine.
2GCEK19R7V1283547
97 Chevy 1500 ecsb 5.7 4x4,Dual flow 40 series without cats,,Wait4Me Tune,3" PA Body Lift
33x12.5x15s BFG M/T on 15x8s,Fully debadged,HomeMade CAI,cowl hood
08-23-2006, 07:12 PM
#17
ill get my vin and edit my post but have you heard any definate answer on the 200 gmc/chevy 1500 fuel gauge intermittent problem..
it shows empty and while driving throw it in neutral and it pops back up but then later it goes back to empty.
I was thinking bad sending unit at the tank but someone said that its probably something behind the gauge cluster since throwing it in neutral fixes the problem
08-23-2006, 08:10 PM
#18
PAINTPEELER
gohard and viz--ill ck in the am and post
as far as the guage working/not working putting in/out of gear i dont see what the relation could be--with the very few clusters we see give problems, it has been speedo issues of jumping around---the clusters are sealed units and nothing back there is moving around....if i had to guess i'd say it had to do with vibrations in the vehicle and more closely the wiring harness to the fuel tank which has been covered earlier in this thread-ask z71dook what he found when he pulled his fuel pump out of the tank//melted wire that got too hot due to loose connection--how many miles on the truck--if close to 100k, it would not be a bad idea to go ahead and get new pump assy from dealer and the new style harness and connector for the body side wiring harness and replace---seems like 100-120k is the magic number for fuel pumps---but get it from the dealer because it will have the new wiring and connector and the pump and you can buy the matching connector for body side
08-23-2006, 11:01 PM
#19
First, Thanks for doing this service. My son's truck has the tailgate cable recall and has had several notices sent, but he has not gone and done it yet. I sat down on it the other day, phone in one hand and beer in the other. both cables broke. Needless to say I busted my A$$!
Is it ever too late to go and get a recall done?
08-24-2006, 05:09 AM
#20
PAINTPEELER
GoHard--shows invalid # or no data found--should still be able to pull up 97 model vins--please ck again
sokkernut--never too late--but it will only be done once to a vehicle--did it damage the tailgate when they broke--GM has also been fixing tailgate that suffered damage when the cables broke---ie hinges or even damage to outer shell maybe from hitting bumper--take the vehicle to the dealer and have them look it over and replace those cables
viz--still waiting for your vin#
| Thread Tools |
| Display Modes |
Linear Mode
