Old 11-17-2003, 04:55 PM   #41
Where's my avatar?
Originally posted by Wayne2
Question: Did they do something to the '03 engines to stop this? I don't see complaints from '03 owners .... or did I just miss something?
Well I'll start--I have an '03 YXL with close to 15K miles on the clock, bought new in Dec. 2002; just about every morning within a minute or two after startup (and still in idle/park) I hear the knocking noise (definitely isn't a pinging noise as I can distinguish between the two, unfortunately--rather not have to hear either one on any of my vehicles, quite frankly). FWIW I believe I first noticed the knocking around the 12K mark; in any case, there is definitely some knocking (not excessively loud but clearly audible at idle) shortly after startup, and definitely after every cold startup.
Fixed after '02? If my FSC is any indication, GM apparently didn't do a thorough job of doing so.
toneman is offline
Old 11-18-2003, 09:22 PM   #42
Oil
I have a 00 silverado 4x4 4.8 vortec with 200000 k I use 5w40 full syn. and use prem. gas every 3 rd. fill also I change the oil every 5000 k and use injecter cleaner every oil change. I have no cold knock or ping this motor runs as strong today as when it was new. The only problem I have had is a exhuast leak at the manifold and when I start it it has a ping till it warms up. This is now been fixed . But I was told the gaskets on 4.8\5.3\6.0 are paper thin and leak making a ping till it warms up. To check put in gear hold brake and give it a little gas if the ping stays the same it might be just a bad gasket.
Diesel
dieselman is offline
Old 11-18-2003, 09:54 PM   #43
Grouchy Old Fart
Wayne2's Avatar
Thanks, toneman. All I hear people talk about is models up to '02 and my '03 is quiet. It only has 9500 miles so far. I hope it stays that way. I already have one knocking. My '02 Trans Am has been to the shop once. The tech called GM and described what he heard. GM says "it is normal for that model".
Wayne Van Metre
'03 GMC extended cab stepside 5.3/A4/3.73 ls & '02 Silver A4/3.23 ls Trans Am (1 of 2370)
Isn't having a smoking section in a resturant like having a peeing section in a pool?
Wayne2 is offline
Old 11-19-2003, 03:30 PM   #44
Where's my avatar?
Re: Oil
Dayum where have you been driving to put that many miles? You definitely hold the world's record for most miles driven in one vehicle...;)
...fill also I change the oil every 5000 k...
And your truck still runs? Man that must be some super-long lasting motor oil you're using--you gotta tell me what brand it is.:kidding:
toneman is offline
Old 11-19-2003, 06:24 PM   #45
Grouchy Old Fart
Wayne2's Avatar
Re: Re: Oil
Good catch. I missed that .
Wayne Van Metre
Wayne2 is offline
Old 11-19-2003, 08:44 PM   #46
Oil type
Maybe I put one two many O's my truck has 200.000 klm.\160.000 miles. Hell thats not even broke in yet my 91 mazda mvp has 541.214 klm.{over half a million klm.} and still runs like new. The oil I use is made by Valvoline for BMW it is BMW'S full syn. 5w40 or Valvolines own 10w30. People who know use Valvoline P.S. Yes I work for Valvoline oil
Diesel
Old 11-19-2003, 08:50 PM   #47
Grouchy Old Fart
Wayne2's Avatar
Re: Oil type
Obviously you DRIVE for them. Dat's a lotta' miles!
Wayne Van Metre
Wayne2 is offline
Old 11-24-2003, 12:11 AM   #48
go go gadget supension
In the Transportation section of the Chicago Tribune Newspaper today (Nov 23 2003) it said owners of GM Trucks (SIlverados, Serrias, Yukons and Tohoes) years 1999-2002 with the 4.8, 5.3, and 6 liter engines have complained about the loud knocking noise. GM acknowledge the problem and HAS BOUGHT BACK SOME OF THE VEHICLES!! But GM says it does not affect engine performance and was corrected it latter models. GM also claims this problem surfaced with the switch to new engines. Lemon law lawyers say they have been getting unusally high complaints about this problem. GM officials say carbon and the amount of clearence between the piston and the clyinder wall are the primary causes of the knocking. Current analysis of 150,000 and 300 000 mile engines have exhibited no cold start noise or significant wear. There is some more to the article but that is the important stuff. Just thought I would post this I find this intereisting to see if my truck devolopes this problem and heck maybe some of you guys could get yer truck bought back!! Another thing I found interesting was that the 2 pictuers they showed for this article were a Yukon XL and a Silverado SS standard cab with 6ft bed, thats the first one I have seen like that bought time GM wised up, now they can really compete with the Lightning.
Jake
2001 Black X-tended Cab LT Z-71 Silverado
run with the pac
"milk is for babies when u grow up u drink beer"
Arnold Schwaneger Pumping Iron
JAKE01blkZ71 is offline
Old 11-27-2003, 01:54 AM   #49
hey
just for everyones info i have a end of the year 03 z-71 almost an 04 and yes it has some piston slap already with around 100 hours on the hourmeter and 3000 mi , its at startup once it warms up for a minute its gone, kinda makes me mad but the thing runs so strong im not to worried about it , sort of is a 5.3l
slappy12345us is offline
Old 11-29-2003, 05:09 PM   #50
Resident Safety Guru
AZdragger's Avatar
don't know if it's this nice AZ weather or something, but i've got 32k on my truck now and don't have a problem at all
Proud father of 2 sons
Jonathan Blake: 8/31/01
Robert Elliot: 6/29/07
My AMERICAN BUILT Ricer: http://s12.photobucket.com/albums/a2...%20Crew%20Cab/
My RICER Toy: http://s12.photobucket.com/albums/a2...onda%20Shadow/
AZdragger is offline
Old 12-24-2003, 02:38 PM   #51
I have 63000 on my 2000 sliverado 5.3 and I don't have this probelm either. One problem I do have is it seems that the driver side vent duct does not have the flow that the passenger side has when the AC is on. I feel like my truck needs an air balance. Does anyone else experience this problem. My passengers will be freezing and I am burning up.
Charger Fan!!!!
Fishin Fool74 is offline
Old 12-25-2003, 10:50 PM   #52
I have an '02 Silverado with 4.8 has 20,000 miles. I don't notice any noise at start up but hear a light ticking noise after it is warm. It sounds more like a lifter tapping than a piston knocking. Anyone know of anything like this? I have been to the dealer, they told me about the CSK, I told them that it's knocking after it's warmed up. They did the top engine cleaner. That didn't really do anything but make my truck stink for a few days. I did get the warranty on the engine so I guess I'll see what happens.
Blk02Chevy is offline
Old 01-01-2004, 06:55 AM   #53
Why do some do it and some dont? My dad has a 1999 with around 40000 and it is quiet, no knocking..
89chevy is offline
Old 01-05-2004, 04:51 AM   #54
01 Charcoal Chevy
yeah same here dad also has 99 and it doesn't knock
RDT253 is offline
Old 01-07-2004, 02:15 AM   #55
Thanks to several of you, I just called the GM Customer Service Line (call center happens to be right here in Austin!) and a real nice guy told me that they would indeed provide me with the 6yr, 100k warranty at no charge. I am not the original owner of this truck either. In addition, he said that it was not essential that the vehicle be under factory warranty.
All I have to do is to visit the dealer who will confirm that said vehicle has the 'knock', then request a repair order with your name and address. Then you call back the GM rep (gave me his full name and personal extension) and let me know where you went. That's it. He will contact the dealer for confirmation and will then mail you the new warranty.
I gotta say, I haven't been this impressed with customer service in a long time. They're basically giving you the same warranty that comes with the Duramax. And it doesn't just cover a failure that is related to CSK; it covers any engine component failure.
That said, my friend who's a mechanic at a Chevy dealership (he's got an '02 2500HD CC 4x4 w/ 8100 and Allison) says the CSK has not produced one failure related to the knock or pistons. It's just more of a nusiance than anything.
PaulS
'02 Chevy 2500HD LT Crew 4x4, 6.0, 4.10s, Fabtech 6" lift, BFG All-Terrain MTs 315x75x16 on 16x8 Xtreme Alloys, and a 90lb black Lab/Rot named Hank. That's Austin, Texas y'all!
PaulSter is offline
Old 02-13-2004, 09:17 AM   #56
Does anyone know if the O - Ring problem was fixed for the '04s. It sounds like my engine is ticking cold or warm, at idle and acceleration. It was there when i baought it and it is really faint. Went on a drive test with the dealer serviceman and he said it has to do with the exhaust. Its not loud right now, but i would like to get it fixed if it needs to. Maybe i should take them the bulletin
Engine Knock or Lifter Noise TSB #02-06-01-038
2004 GMC Sierra 2500LD 4x4 SLT CrewCab SB Onyx Black, 6.0L, Auto
grimm2420 is offline
Old 02-13-2004, 11:55 AM   #57
mine only does it on rare occasion...
not nearly consistant enough to reproduce it on command for a dealership...and only when its cold... which would mean leaving my truck there over night for them to try starting in the morning... which aint gonna happen...
Lucas is offline
Old 02-19-2004, 10:23 AM   #58
I just back from the chev dealer in Princeton MN, I took my 6 liter 3/4 ton gas truck in to have them listen to it cause it sounds like a diesel. guess acording to them it not the slapping problem & more than likly isnt anything to worry about. how ever they could check it out for 1200 tear down & the same to put it back together. Couldnt I buy a new engine for less?
3 slappers is offline
Old 02-19-2004, 01:50 PM   #59
Truckless :(
HENRY's Avatar
Id contact GM customer service. Damn service people always try to pass something off as nothing.
Maybe take it somewhere else.
___
HENRY is offline
Old 02-19-2004, 03:30 PM   #60
Henry is exactly right. Call GM Customer Service (you can find the number on the GM website) and explain to them the problem you had. I had a Chevy Service Advisor try to do the same thing. He said something like "yea, we'll listen to it, but it's normal and within GM operating guidelines." Gave me real attitude. I call Cust Service back and they conference called me to the dealership.
To make matters worse, I had to leave the truck overnight (reasonable, since it needed to be cold) and I wasn't there when they listened to it the next morning. When I picked it up, they said there was nothing wrong with it! So they had a service guy pull it around front for me. I immediately shut-off the engine and grabbed the Service Advisor. I said "listen to this" and when I said that, another customer and her Service Advisor heard me and turned around. I started the truck ('02 2500HD 6.0) and we ALL listened. Nothing happened for about 15 seconds--then it started! It was GREAT! The woman who was there with her Suburban says "Oh, I can hear that!" and the other Service Advisor nodded his head in agreement.
Anyway, he quickly, and sheepishly, changed the ticket to reflect that he heard the CSK. That was about 2 weeks ago. A few days ago, my letter from GM arrived informing me of my 6 year, 100k warranty on ALL engine components!
Persist my man! Don't let the jerks at the dealership take advantage of you.
PaulS
PaulSter is offline
