Old 04-21-2007, 08:32 PM   #161
1badasschevy
Like A Rock...
1badasschevy's Avatar
Member ID: 67695
Re: Recalls & Engine Knock Info
I'm having the same problems with my 02 5.3. It knocks like a mofo when I'm towing and it downshifts. It's going into the dealer soon. It just topped 80K miles. I figured I just beat on it too much. I tow with it 80% of the time.
2002 Chevy Silverado 1500 (Lowered!)
1996 Chevy Tahoe LS (Lifted!)
Old 04-27-2007, 07:19 AM   #162
pds318@verizon.
Paul D350
Member ID: 67419
I've got an '02 Silverado with the 5.3L Vortec. About 50% of cold start-ups produce a tapping noise that to me sounds like a bad lifter. The knock will only stop after about 15 - 30 seconds of actually driving the truck, i.e., putting the engine under a little load.
You can let it idle, or even rev it slightly for 2 - 3 minutes before driving it, but it will still knock until the engine gets driven with a load on it. The knock will then go away after 15 - 30 seconds.
Does this sound like a bad lifter or the above-mentioned piston ring carbon issue?
I though it was just a weak lifter that was leaking down overnight
Old 05-25-2007, 11:42 PM   #163
UnderBoost
UnderBoost's Avatar
Member ID: 69243
Originally Posted by pflug24
just out of curiousity what octane fuel and weight oil is everyone using that has the knock in their engines?
I run Royal Purple 5/30 and cheveron 87. I have that knock also
it sounds like one big spray can being shook.
00 LS Chevy 5.3 Extra Cab. Stock
87 Buick Grand National
Old 05-26-2007, 12:05 AM   #164
CuZtOm90
Stock sucks
CuZtOm90's Avatar
Member ID: 38514
I also use royal purple 5/30 and 91 octane and have this same sound knock in my 5.7...I never get it on start up I get it sometimes when I jump on the gas from a roll, what could this be? Sounds like a rattle can being shook real fast..
Old 06-01-2007, 11:57 AM   #165
Biohazard827
Member ID: 69539
I have a 2000 Silverado 5.3L w/ 110,000 miles on it, I have the same engine knock for about 5-10 min. upon cold start. I also have a loss of power upon cold start as well, especially when the trans. is shifting from 1st to 2nd. It almost feels like it's gonna' die. Any thoughts?
Old 06-01-2007, 08:23 PM   #166
thecodeman
the Waco kid
Member ID: 1522
My 02 tahoe with 85k miles, using 5w30 mobil 1 and 87 octane Shell knocks at startup just like my 03 avalanche 2500 with 45k miles, same oil and same gas. it goes away when its warmed up, but the first thing my father in law asked me when I got the avalanche last year was "Is that thing a diesel?"
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
Old 06-03-2007, 07:06 AM   #167
podatchevy
Member ID: 69079
Originally Posted by russo_z
In most cases it is a Carbon build up...you can purchase cleaners at your local store for cheap...if problem remains then you should begin to worry.
Zach Russo
Automotive Editor
www.reply.com
carbon build-up my a. Just another stupid excuse from gm trying to cover up a poorly designed motor.
Old 06-18-2007, 06:33 AM   #168
jwko
Certified ShadeTree Idiot
Member ID: 54929
I have a 98 (5.7) Sierra with 195k & a 01 (4.8) Sierra with 124k, both have the same cold start tick or knock and have always had it since almost new. Neither engine will use any oil or smoke but the difference with the 01 is will not knock at idle, just when u pepper the gas you will hear it the after about 30 sec's to a minute its gone. The 98 will knock after startup at idle also while driving for about a min or two. The outside temp has to be pretty cold (maybe 45 degrees or colder) for this to happen.
I have read everywhere that GM say's " This is not a problem " but anything that tick's, knocks, scrapes ect is wear. I don't think its carbon I think its the change from hot to cold & aluminum pistons. Am I Crazy?
Another thing, both of my trucks have always had a slight spark knock when using low octane fuel, the 89 octane corrects this...HMMMMM, maybe it is carbon...At this mileage I would be afraid to decarbonize them.
I guess I will just drive em till the wheels fall off then buy another. No matter how you look at it, coulda been worse, could own a Ford
1982 Chevy
1986 Chevy
1998 GMC
2001 GMC
2001 Taurus
Old 07-06-2007, 03:30 PM   #169
CIWS33
03 2500HD4X4Crew Cab 8.1L
Member ID: 68560
I have an 03 2500HD 8.1 that has been slapping since 9K, (almost 50k now) same story at the dealership considered "normal" so being the tactful individual that I am, I asked him if the noise is normal should I bring in my Burb because it didnt make noise. He didnt find it as funny as I did anyways....I use Royal Purple and it doesnt help the noise issue at all.
Old 07-06-2007, 03:37 PM   #170
Koots
Can I Hab Some?
Koots's Avatar
Member ID: 53530
sounds like you have some sticky lifters. use a little oil additive (like AC/Delco's stuff) just to keep it free moving and out of aural range.
<-Thanks Chuggs
I Think It's Time We Empty Our Hands Of Guns, So We Can Fill Our Hands...With Hugs
Old 07-06-2007, 03:40 PM   #171
Koots
Can I Hab Some?
Koots's Avatar
Member ID: 53530
maybe try using 10W30 could help too. i use 10W in the summer and 5W in the winter. my engine sounds a lot smoother when i use them this way. 5W seemed to be just too thin for the heat coming from my engine and the heat from the outside
<-Thanks Chuggs
Old 07-09-2007, 06:53 PM   #172
candidate zero
Member ID: 68671
I have an '01 with a 5.3, 117k miles. Mine does it for just a couple minutes on start up. My LS1 does it very slightly, not as noticable as my truck. My truck runs great, has good power, and gives me no problems. I run Mobil 1 10w30 and it doesn't use oil. I'm used to it now.
'01 CamaroSS
'01 Silverado Z71
Old 07-12-2007, 11:39 PM   #173
Trolin
GONE FISHIN'
Trolin's Avatar
Member ID: 42462
I have an 2001 5.3L w/ 66K that had always had the slap on cold starts. Switched to a 10W synthetic AMSOIL and good oil filter and haven't heard a thing in months I think a heavy oil may be worth a try. >>>just my two cents<<<<
Old 07-14-2007, 11:10 AM   #174
FoxRacing_149
FoxRacing_149's Avatar
Member ID: 7609
i've got the same prob. on my 99 i've done everything i can think of and it still does it done the top end cleaner switched to 10 30w with lucas additive also my change engine oil flashes peoriodically and i just changed it it only has 500 miles on this oil change
99 ext cab z71 5.3 ford keys 4'' lift blocks 16x10'' mb rockers with 305/70's westin bull bar 40 series flowmasters
Old 07-14-2007, 12:38 PM   #175
Koots
Can I Hab Some?
Koots's Avatar
Member ID: 53530
if your goin to wyotech (lucky f***er) get a new cam and a set of lifters. usually the lifters come with the cam (not on the 96-98 OBS) and now you have a full world class garage at your disposal and you get a little extra juice from your Gen III motor.
<-Thanks Chuggs
Old 07-15-2007, 04:38 AM   #176
FoxRacing_149
Member ID: 7609
are u talking like a performance cam or just a replacement ?? but yea i just started ems 2 weeks ago
Old 07-15-2007, 12:00 PM   #177
Koots
Can I Hab Some?
Koots's Avatar
Member ID: 53530
yeah a performance cam is what i meant. and hopefully everything works out well for you man. wyotech is my dream school, like harvard for the book learning types. how mch did your enrollment cost and all the other stuff, if you don't mind me askin? if it is not astronomical i might be able to go in a couple of years.
<-Thanks Chuggs
Old 07-25-2007, 07:54 PM   #178
Giterdun
Member ID: 38078
Does the TSB (#01-01-39-004A ) cover the 2003 silverado as well?
Old 07-31-2007, 03:30 AM   #179
jwko
Member ID: 54929
The 03: TSB #020601038 -- ENGINE KNOCK OR LIFTER NOISE. *TT (NHTSA ID #10000763, DECEMBER 01 2002)
found here:http://www.carcomplaints.com/Chevrol...003/tsbs.shtml
1982 Chevy
1986 Chevy
1998 GMC
2001 GMC
2001 Taurus
Old 08-12-2007, 08:45 AM   #180
KyRob
Member ID: 70451
Anyone got the 6 yr/100,000 mile xtended warranty on their out of warranty truck lately for knocking or other issues? Mine is an 04 (warranty ran out last month)with the 5.3 and ticks a bit at start up and I am just starting to hear the steering klunk that many speak of. It only has 27,000 miles on it now. Is the steering klunk a recall?
Rob
