05-10-2008, 09:06 PM
#21
Re: 98 350 No Start Issues.
Problem with a code for cam/crank offset is, it is already out of whack because I changed the oil pump a while back put it back on my marks but the code still comes up so I just have to be a little off, but my scan tool isn't good enough to do the offset reading so all I know is I already had that code so it doesn't help.
Just turned 100k a coupla weeks ago.
Got a compression tester tonight so I will get numbers in the morning.
Kinda hoping its the crank sensor.
98 C1500 EC Step Side: 350, DI/DO Magnaflow, K&N filter, 3.73's, 33x10.50, 15" Cragar V-5, 4" susp. lift, 1" body lift, red top, big 3, rollnlock, halo head lights, clear corners, black tails, cb/pa, light bar
05-10-2008, 09:17 PM
#22
Also is there any "cheap" laptop based scan tools that I can buy? I don't mean like 50 bucks by cheap I mean just not thousands.
05-11-2008, 11:03 AM
#23
Compression is:
160, 175
178, 147
146, 93
178, 120
FRONT OF
ENGNE
I Am thinking that I somehow flooded the engine and dried the rings out.
What happens when the spiders on these trucks go bad and what is the fuel pressure supposed to be at?
06-25-2008, 01:32 PM
#24
Texas, Where are you from
Originally Posted by Fishnfergie
Compression is:
160, 175
178, 147
146, 93
178, 120
FRONT OF
ENGNE
So are we getting spark? Are the plugs wet?
Only three things for it to run and I think you are getting air in right?
Rich
Rich
1994 C1500 Suburban
1999 K2500 Suburban
Why doesn't Buick ryhme with Quick?
06-25-2008, 02:07 PM
#25
GMC RULZZ
your fuel pressure is good if its at 65 psi. I believe its supposed to be at 60 psi or above for it to even start.
 Matching Ninja 500r
01-20-2009, 06:57 AM
#26
What was the outcome to this problem?? My truck is suffering from a misfire that happen after a loud pop. Within one second my truck went from great to a terd.
FOR SALE $8200: 1997 Yukon GT
BFG 285's, true duals w/bullets and no cats, and K&N FIPK
| Thread Tools |
| Display Modes |
Linear Mode
