Old 05-07-2008, 02:51 AM   #1
JadXtreme
longbeds rock
JadXtreme's Avatar
Member ID: 88325
89 turn signal switch
On my turn signal switch, it has delay windshield wipers, cruise control. The high beam part doesn't work. I can pull it back to turn on the high beams, but the switch doesn't click when I pull it back. Also, when you use the left turn signal, it doesn't come back up after you make the turn. I was wondering what it would take to fix this. I found a new switch for it in the LMC catalog, but the switch for my truck is almost $100. Will the switch w/o delay wipers and with cruise work on my truck? That switch is only $40. I know that there is also another switch that goes inside the column that goes around the column, could that be part of the problem as well? I'm not sure which switch it could be. Please, any advice would be much appreciated.
1989 Chevy 1500 regular cab long bed. Leveled out with metallic silver paint. Navy interior. Chrome 15" Pacer wheels. 350 TBI 700R4, and true duel glasspacks.
Old 05-09-2008, 12:05 AM   #2
bluehewes
Member ID: 88855
Re: 89 turn signal switch
Replace the turn signal switch that should fix your problem. I just did mine and found the part for 25 bucks.
good luck!
Old 05-09-2008, 04:22 AM   #3
JadXtreme
longbeds rock
JadXtreme's Avatar
Member ID: 88325
Where did you get your switch from and which one was it?
Old 05-13-2008, 03:33 AM   #4
JadXtreme
longbeds rock
JadXtreme's Avatar
Member ID: 88325
I found the switch on latemodelrestoration.com for around $45. It sure beats $100 in LMC.
Old 05-17-2008, 07:59 AM   #5
dave89iroc
dave89iroc's Avatar
Member ID: 73893
through 94, wiper switch, high beam switch, turn signal switch and cruise/turn signal arm are all separate switches
adjust the high beam dimmer switch, and that should click
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet
