#1 |
Member ID: 67135
Hey Guys.
My 01 Sierra was totaled a couple months ago so I bought a 07 Avalanche. It has the new type of oil life system. Now my question is at what % of life remaining do you change your oil? I’m sure most of you don’t wait until you’re at 0%. What about if you are using synthetic oil? I used mobile 1 in my last truck and will be using it again with this one. What do you guys do? ![]() |
#2 |
"ALWAYS".....M1 full syn.
Member ID: 65262
Re: Oil life question!
using a good syn. oil you should be able to go to 0 or 10% with
no problems at all..
1999 1500 Z71 4x4 5.7 Vortec G80 3:73 LS Extended Cab Shortbed
#3 |
Member ID: 79217
Don't read too much into that indicator. It just calculates hours, rpm's, speed, etc., and basically guesses on your oil life. It doesn't know, for example, if you are using some 10 year old off brand oil you bought at a garage sale, or, Mobil 1 Extended performance full synthetic (lasts for 15K).
You are by far the best judge of when to change. |
#4 |
Member ID: 32449
My oil life indicator comes on at 4.7% in my 2000 Suburban. The mileage I've driven varies from 4000 to 5000 km.
Signature removed by FSC Staff for exceeding the 500x200 limit.
#5 |
My four current trucks 2000-01-03 & 04 have used Mobil 1 and always used the OLM from there delivery day, the oldest has 243000 mi without any internal repairs. Oil usage is about the same as new considering there business vehicles.
The OLM is very accurate and with the Mobil 1 its well protected.
04 K1500 Silverado EXT 3:73 gears, 265/75-16,Pace Edwards tonneau, Jesse's tune,C5 elec cooling fan.
#6 | |
Premium Member #120
Get in sit down hang on.
Member ID: 7737
You might want to read up on the OLM, it does a lot more than that. ![]() 5.7, FIPKII, Elect Fans, S/S Headers, Duals, Wait4Me, 4/5 drop on 18" Weld Evo Velosity's. STOLEN ON 9/9/2006 http://www.fullsizechevy.com/forums/showthread.php?t=229807 |
#7 |
Here is the info on the OLM.
GM OIL LIFE SYSTEM...HOW DOES IT REALLY WORK This is taken from the May 2003 GM Techlink publication How often should engine oil be changed? 3,000 miles, 5,000 miles, 7,500 miles, 10,000 miles? Actually, all of these are correct, depending on operating conditions. Oil life is affected by many factors other than just miles driven. The type of driving, temperature, and engine load all play a part. That’s why GM has developed the GM Oil Life System, an electronic watchdog that keeps track of all these variables and notifies the driver when it’s time to change oil. This system has become standard equipment on nearly all GM products since 2000. Briefly, the Oil Life System is programmed with a certain number of engine revolutions. As the engine runs, this number is reduced until it reaches zero, and the Oil Life light or message comes on. But there’s more. Operating the engine under low or high temperatures, and under high load conditions subtracts (penalizes) extra revolutions, so the light comes on sooner. Changing engine oil according to actual need rather than an inflexible schedule provides several benefits. First is simplified determination about when to change oil. No more decisions about normal conditions vs. severe conditions. Second is reduced operating costs for GM’s customers, who now have to change oil only when it’s needed. Third is minimizing the amount of used oil that must be disposed of. And fourth, engines will always be running with sufficiently fresh oil, for long life. Traditionally, the vehicle maintenance schedule has been based on miles or time, while the oil change interval is now based on the GM Oil Life System. When the change engine oil light or message comes on, it means that service is required on the vehicle. I should be serviced as soon as possible within the next 600 miles. It is possible that, under the best conditions, the engine oil life system may not indicate that vehicle service is necessary for over a year. However, engine oil and filter must be changed at least once per year, and at this time the system must be reset.
#8 |
Member ID: 75236
letting GM tell you when to change your oil is almost as dumb as thinking you have to use GM oil and filters
2006 4x4 ECSB Silverado 5.3, 285/70/17 Cooper STT tires, Magnaflow duals out the back, SLP cold air intake, KYB Monomax Shocks, color matched Bug Shield, Billet Grill
#9 | |
um....yeah
Member ID: 11351
not saying I agree or disagree, just stating that the manual they put in the cars say so....
Finally!!!! I bought a fullsize!
2005 Silverado extended cab |
#10 |
243000 mi on my oldest truck 2000 Silvi EXTSB and still running great. OLM has worked great on mine and my Blackstone lab. oil reports say so too.
#11 | |
Member ID: 87774
I was going to suggest that very thing. Use Mobil 1, run it down to 10% and get a Blackstone Labs test on it when you change it.
1999 Tahoe LS 2-Door 4x4 w/ 3.73 G80. Custom tune from Justin @ Black Bear and a Vette 1 - 2 servo.
14 Bolt SF Project Underway Brakestands make for great aroma therapy. |
#12 | |
Member ID: 75236
#13 |
Member ID: 75767
Oil is not a living thing!
Theirfor it has not life. ![]() 96 Silverado ECSB, 350, 4L60E, 3.42 G80 89 Camaro, 5 speed, 3.08 LS 49 F-1, flathead 6, 4 speed, 2wd, unknown rear end. Old rust bucket. |
#14 | |
Member ID: 79217
Ummm...I just did, I read the quote from redvett01's May 2003 GM Techlink publication. Actually, it comfirms just what I said. It measures hours, rpms, etc., and guesses. It does not know what kind (quality) of oil you are using. I use Mobil 1 Extended Performance , gauranteed for 15K. The OLM doesn't know that from 10 year old junk oil. Last edited by gfh77665 : 05-13-2008 at 12:43 PM. |
#15 | |
Married with Children
Member ID: 77159
This is all too complicated. Just change it somewhere in the 3000-7000 mile range-whereever you are comfortable. Use the OLM if you want. 3000 is probably overkill, but that's what I do because I only drive 3000 miles every 6 months or so. If I drive it more I'd probably to to 5000 miles because that easier to remember with the odometer. 7000 is fine-I've seen many cars last years doing that.
Just make sure you do it enough to avoid warranty trouble if for some reason something does go wrong. I know for a fact that a 1999 Malibu will last exactly 67,000 miles on the original oil. I saw one. Locked up without an ounce left in it, but not bad considering.
Wildcats 4-1 Steelers 4-1
'03 CCLB 4x4 6.0 tuned by Justin ![]() '06 Stratos 185 Pro XL 150 Merc Optimax '02 Acura MDX Quote:
#16 | |
Member ID: 67135
What king of filters do you guys use? I have one mobile 1 filter left and a buddy just gave me about a dozen AC filters. My new truck! ![]() |
#17 |
When i worked a GM engineering (retired) i saw engines that power-train ran Mobil 1 and used the OLM & only changed the oil filter at the OLM requirements and many engines went 1 million miles. That convinced me that the OLM was doing its job but since i have been using M1 since it came out in around 1973 & i really didn't have to be convinced about Mobil 1. I have been using the OLM in my vehicles since the early 90"s. I am happy with modern day engines getting 300K without any internal repairs.
#18 |
Homesick NBer
Member ID: 31582
Location: New Brunswick, Canada(working in Edmonton, AB)
does it not sound stupid to wait until a warning light comes on in the dash, that tells you you should do something, why not just go with the old 3000mile/5000km oil change interval, just look at the sticker in the corner of the window.
i mean i work at a dealer and have to deal with these things every day, and i don't like them, i honestly beleive this makes people lazier, they just drive till the light comes on, whats the point, when you hit 3000miles just take it in,or do it youself, simple.
1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates 89 W/T Grille, fender flares coming.
![]() GM trained 2nd year apprentice at a Chev Dealer |
#19 |
Member ID: 24894
The OLM is not a warning light, its simply a timer/counter as others have stated.
My first vehicle was an 1988 s10 we got from a repo auction and dad changed the oil every 6 months. When I moved graduated college I started changing the oil every 3000 miles. I tore the engine down at 170,000 miles and took the block to a machine shop and they still saw the crosshashes from when it was machined and were surprised that I had it in for such low mileage, they thought it had under 50k on it. So when I got my newer S10 I switched to mobile 1 and went to 6k changes. Now with my silverado the OLM says change oil at around 6k anyway so I go by it. I rotate the tires and grease the joints and such at the same time.
2004 Silverado ECSB Z71 5.3L 4L60E
Mods So Far: Bug Deflector, Glove Box Light, Floor Courtesy Lamps, Console Power Port, Cobra 25 NW ST WX, Wilson Little Wil, Surepower 120A Battery Isolator and second battery. BFG AT KO 285/75 R16. Ranch cap with Tahoe z71 roof rack. |
#20 | |
Changing oil at 3K is a waste of resources.
| Advertisements |
| Thread Tools | |
| Display Modes | |
