#1 |
Move Over!!!!
Member ID: 81181
Changing trans fluid
The trans has been slipping for a bit on me so I decided to change the fluid. When I do, I was thinking of adding a deep pan and wanted to know if anyone has this pan and if its any good:
Derale Transmission Pan Coolers use the air flowing beneath the vehicle to reduce fluid temperatures from 20°F to 50°F. Features include heavy-gauge stamped steel construction, patented turbulator cooling tubes and a zinc plated finish. Increases fluid capacity. Replacement pan gasket included. Will not fit applications with OEM deep pans. Adds 2 QTs. 3.5" Depth, Tube Depth is at 2.38", Drain Plug Included. ![]()
'99 Tahoe Z71, on your basic 265/75/16's
MSD coil MSD 6A ignition Accel cap and rotor taylor wire set Volant CAI Flowmaster 40 Series Si/So with Edelbrock TES headers Jet Performance hand held tune All for a 5mpg gain currently @ 20mpg |
#2 |
Truck shopper
Member ID: 92250
Re: Changing trans fluid
why not use a trans cooler, or larger trans cooler if you already have an OEM one? I would be afraid of those pipes corroding out from water/salt/mud and causing a far worse issue.
#3 |
Move Over!!!!
Member ID: 81181
That's what my thoughts were, but I wanted to check and see if anyone had tried it and what the outcome was.
#4 |
Member ID: 92704
I agree with the cooling lines on the pan...seems a little risky to me.
I bought a deep pan but it was from Trick Flow and held an additional 2 quarts and had external cooling fins cast into the pan. Looks great but the thing would NOT stop leaking for the longest time...took 4 gaskets before I finally got it just right. I already have a OEM trans cooler but our summers here hit 110-120 regularly so I figured extra cooling wouldn't hurt. ![]() 96 Chevy K1500 5.7 Z71 65K miles K&N FIPK Edelbrock Headers Flowmaster dual exhaust Hypertech programmer Royal Purple fluids MSD wires braided brake lines cross-drilled/slotted rotors heavy right foot
#5 |
Status:
Online
Member ID: 73893
those are decent pans, and yes, they do help to keep the fluid temp down
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet |
| Advertisements |
| Thread Tools | |
| Display Modes | |
