#1 |
formerly 133
Member ID: 36391
Bolts to pull motor and hold on stand?
What are the bolts I need to screw into the vortec heads to pull my motor and hold it on a stand?
97 yukon Plans- Lift, line-x/rhino lining inside/outside, fresh motor/small cam, much more!
04 hyundai elantra Plans- Trade for a white 97 M6 No Farms-No Food
#2 |
Member ID: 34288
Re: Bolts to pull motor and hold on stand?
To hold it on the stand are 3/8 -16 if I remember correctly.
2000 Silverado Ext. Cab Z71
2005 Nissan Titan XE |
#3 | |
miss you Rachael
Member ID: 60291
Every time I pull a motor I just use the exhaust manifold bolts. One in one side all the way at the front and one on the opposite side on the back.
70 Chevelle-94 RCSB-95 2 dr Tahoe-96 4 dr Tahoe for parts Quote:
#4 | |
Member ID: 92890
wut he said |
#5 |
formerly 133
Member ID: 36391
Thanks tatood. Got plenty of those suckers laying around. You ever gonna make it down around richmond,va or nc?? Love to meet you and see the truck in person.
#6 |
Status:
Online
Member ID: 73893
3/8-16 is the thread
use either the exhaust manifold holes, or a hole on the front of 1 head, and the rear of the other head as for bolting it to a stand, same thread, but you need bolts long enough to go through the stand arms and have 1/2-1" out the end(1" preferred, if they bottom out, use a couple washers till it doesn't, more thread in the block, the better(and safer)it is)
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet |
#7 | ||
miss you Rachael
Member ID: 60291
No problem man. I was in Virginia Beach Monday night picking up that Tahoe, lol. How far from Richmond are you? 70 Chevelle-94 RCSB-95 2 dr Tahoe-96 4 dr Tahoe for parts Quote:
#8 |
formerly 133
Member ID: 36391
Around 2-3 hours. My g/f's dad lives in chester so im up close that way a dozen times a year.
#9 |
formerly 133
Member ID: 36391
Another question. What bolts need to come out on the trans side of the motor to pull it? Man im a newb at this. All the acc on the front of the motor are pulled, now I just need to get the engine mounts and whatever on the trans side to pull it.
#10 | ||
miss you Rachael
Member ID: 60291
Do you mean the back of the motor where it bolts to the trans? If you are pulling the motor only you need to remove the bolts from the bell housing to the motor, there are 6 or 7. You will also have to remove the bolts that connect the flywheel to the torque convertor. 70 Chevelle-94 RCSB-95 2 dr Tahoe-96 4 dr Tahoe for parts Quote:
#11 |
formerly 133
Member ID: 36391
pulling just the motor. Would it be easier to pull them both? I see 6 bolts on the bottom that dont bolt to the engine. Then the ones your talking about are above those? They look near impossible to get to.
#12 | ||
miss you Rachael
Member ID: 60291
There should be a some on the bottom for the torque convertor/fly wheel cover. You have to take that off to get to the torque convertor bolts. The one I'm talking about are kind of hard to get to but it's ot too bad. I'll take some pictures in a minute of what I'm talking aout. 70 Chevelle-94 RCSB-95 2 dr Tahoe-96 4 dr Tahoe for parts Quote:
#13 |
If its 2wd might be easier if you just pull the tranny and motor together if its your first time. Otherwise the top bellhousing bolts can be tricky from the bottom without long extensions and wobble/ujoint sockets.
89 Burb 1500 2wd
79 Mustang 460/c4 03 Dakota QuadCab 4x4 (work truck) |
#14 |
formerly 133
Member ID: 36391
its 4x4.
Thanks tatood.
#15 |
formerly 133
Member ID: 36391
Got that cover off. Now the exaust/trans cooler lines/ driveshaft is in the way. Do I need to pull the driveshaft?
#16 | ||
miss you Rachael
Member ID: 60291
I dont think that you would have to take the driveshaft out. You can probably get creative and get to the bolts. I didnt get to put pictures up last night, we had crazy storms and our Comcast was acting screwy. I'll get em up later. 70 Chevelle-94 RCSB-95 2 dr Tahoe-96 4 dr Tahoe for parts Quote:
| Advertisements |
| Thread Tools | |
| Display Modes | |
