11-19-2008, 11:27 PM
#41
Re: Uh oh. The hood is stuck
my '89's hood has had the same issues for the past 10 years, i've adjusted the bumpers, oiled, greased, moved, bent, and tinkered with just about everything on there. it's just cantankerous. usually just a little upward bump with the side of my hand is all it takes...it's been doing it so long, it doesn't bother me anymore, i find myself hitting other people's hoods now just out of habit.
11-19-2008, 11:58 PM
#42
DUH! Big Red Truck!
Originally Posted by skills4lou
Hi, my name is Greg and I'm been hood-whacking for about 15 years now. Recently I made the mistake of applying lube to my OBS, so I no longer HAVE to whack. But I really want to. Please forgive me. I've been having withdrawals!
remove your pop up spring off the bottom of the hood, then compress it in a vise. now apply a little heat to it, and you'll have to start wacking your hood again.
seriously, when you have it open, reach up and grab the spring. give it a good tug and stretch it back out. over time, being compressed most of its life, it starts to lose its spring. stretching it back out helps out for a little while.
11-19-2008, 11:59 PM
#43
OBS Hood whacker here. Sorry, ya look cooler walkin up to the hood and givin it a lil tap. Tried the lube tricks but I really don't mind the whacking. Besides, when you have a dead battery, it gives you some level of satisfaction to smack yer truck for bein mean to ya.
11-20-2008, 12:00 AM
#44
hold my beer & watch this
I'm a hood-whacker since the engine swap haha
Still building up to the SAS...
and the Whipple install...
ugghhhh
11-24-2008, 12:53 PM
#45
My hood opens up fine, it pops up when I pull the latch, but on my brother's 89 you have to pop the hood with your fist. It works every time but I should put some WD-40 on it.
91 RCSB C1500 4.3 4L60 Cash for Clunkered 8/3/09
09 Ford Mustang Bullitt #5998 Brenspeed Tune, LCAs. 13.4 @104.3
94 Ford Mustang SVT Cobra Way too much to list. SOLD 9/4/08
11-24-2008, 03:08 PM
#46
Finally got the Dmax!!!
Then your bro should be in the OBS hood whacker club!!!
NEW TRUCK!!: 07.5 4x4 CCSB LTZ Dmax
Old truck 1992 1500 ECSB 4x4 350TBI-700R4 304k miles
2X member: OBS Hood-whacker Club <-- Join us!!
Tow Pig '95-2500, 454TBI, NV4500, 2wd
11-24-2008, 05:41 PM
#47
Flawed Behavior
WD40 isn't going to do any good, well at least not long-term. It's not really lubricant. Use white lithium grease and get it behind the pawl, not just on it. The part that needs lubing is where the pawl rubs against the latch, helps if you gently spread them apart with a screwdriver just enough to spray the lube in there.
Richard
94 C2500LD, 94 3500HD, 98 C3500, 48 Harley chopper
Free beer tomorrow
11-24-2008, 06:10 PM
#48
Just a light wack man. Don't beat it with a frickin sledge hammer Been doing it for 10+ years no dents
11-24-2008, 06:28 PM
#49
x2 on the hood whack. Once you get the technique it's second nature.
(once you get it open you can spray some white grease in there, but then you don't get to do the cool truck guy hood whack!)
same thing on the yukon. wd40 = mr fixit
03 5.3L ECSB Z71
some of this, some of that
97 6.5L Diesel 2DR Yukon
11-24-2008, 09:09 PM
#50
its more of a slime than grease isn't it? wait what are we talking about?
11-25-2008, 06:58 PM
#51
my truck did this and i had to set the stop on the line going to the latch. if you push down on the hood you can get it to pop. than look down on the latch and see if the stop is near the end of the line. if it is move it up some and see where that gets you. that what i did to fix my problem.
11-25-2008, 09:09 PM
#52
You hood whackers should try using some penetrating oil to free up the latch assembly first then give her a shot of lithium grease once you get all the crude off.
11-25-2008, 09:33 PM
#53
My hood opens fine until winter...then i have to start whacking. Last year my battery kept dying because i left stuff on, so i'd pop the hood but it wouldnt pop because its half frozen half in need of a whack. So i whacked it so hard it dented and chipped
I must say the whack is so much cooler then the hood just popping open.
90 SCSB Stepside 4x4 350, 14 Bolt, K&N filter, TB spacer
92 Mustang 347 H/C/I
11-25-2008, 09:49 PM
#54
Flawed Behavior
A couple of times my battery went dead, I'm freakin' glad the hood opens easily, because I couldn't pop my doors. Wedged the door a little then used my lockout tool to pull the hood latch and hook up the battery charger, jumper cables would work too, then I could pop my doors.
Richard
Free beer tomorrow
11-25-2008, 10:48 PM
#55
2 people one pulls the hood while the other pulls the plastic thing thats how i have to open some of the fleet trucks cause they aint workin right
11-26-2008, 06:14 AM
#56
A great method if you don't mind repainting the whacked hood often.
11-26-2008, 08:34 AM
#57
man... I've whacked mine pretty hard and never dented it. I've never even chipped the paint. You must have been pretty pissed to whack it that hard! All I ever have to do is just give it a light tap and it pops up every time. I've never seen an OBS with a hood dent from gettin whacked too hard come to think of it.
11-26-2008, 09:32 AM
#58
When I whack, I use open palm.
Feel free to take that out of context.
1999 Tahoe LS 2-Door 4x4 w/ 14 Bolt SF & TruTrac. Corvette 1-2 servo, Gibson cat-back, custom PCM tune by Justin at Black Bear, AD244 alt. upgrade, 4 high headlight mod
Proud member of the OBS Hood Whacker Club
GMT400: Making Mother Nature your b*tch since 1988.
11-26-2008, 09:45 AM
#59
I thought hood whacking was standard practice. Ive lubed mine with white lith also with no luck.
Ive been doing it for 4 or 5 years now and still have no dents.
98 K2500 / GMPP 350HO / 4L80e / np243 / 4.10 / 285's
On the list to come:
Hooker 2462 / Plenum Spacer / 2700stall / Blackbear 93 oct tune
11-26-2008, 01:51 PM
#60
wait for it...
wait for it...
join the club!!
BA HAHAHHAHAHA
man I'm freakin hilarous!!
| Thread Tools |
| Display Modes |
Linear Mode
