10-29-2008, 04:21 PM
Uh oh. The hood is stuck
I went to pop the hood today and instead of a thunk, I get nothing. I can hear the cable sliding on the latch end so I'm assuming it's just loose.
Now opening it with a screwdriver wouldn't be a problem except for the latch guard. So I was wondering if I could get some help with this
Thanks, Levi.
1994 GMC SCSB. 350, 3.08's  Transgo Hd2, 2k stall TC, Heddman longtubes/SLP LM1 duals, Ult TBI mods, XtremeFI AFPR, 2inch drop shackles
Originally Posted by javi05
i dont care what anybody says but man sex will be on my mind till i am 70. crazy stuff on craigs list. lol.
10-29-2008, 05:28 PM
#2
Diesel Nut
Re: Uh oh. The hood is stuck
Good ol trusty coat hanger. make a little hook and hook the latch and pull to the right. (drivers side)
2007 3500HD NBS Duramax
10-29-2008, 05:31 PM
#3
Isn't so crazy afterall?
One of these would probably work.
:jk: My hood doesn't "pop" sometimes but if I go push up on it by hand it pops....I'm assuming you tried that?
10-29-2008, 05:56 PM
#4
Thanks for the help.
Also, the JOL would give me an excuse to get a cowl hood lol.
10-29-2008, 07:29 PM
#5
Mine does the same thing usually i just push down on it slightly and then it will either close or pop up. One way to fix it is unscrew the rubber stops at the edge of the front fenders just enough to put enough pressure to pop it up everytime the latch is opened.
I like the JOL personally too
10-29-2008, 07:45 PM
#6
6.0 swap starting..
give it a sold wack right on the front edge..mine used to stick and that would pop it open..if not, just get something in there to pull the cable through the grille..if you can see the cable pulling the latch, then youll have to pry it up or hit it like i said..should open
2000 Tahoe
24" Boss 330, 295/35/24 Nittos , 3/5 drop
6.0 LQ4 swap, BB 93 Octane tune, Magnaflow, e-fans, CAI, HD2 shift kit
18" BTL w/ Kicker 2500.1 2703 watts, Dual Optimas,Pioneer 4100 DD, Esky Cluster
10-29-2008, 08:10 PM
#7
x2 on the hood whack. Once you get the technique it's second nature.
(once you get it open you can spray some white grease in there, but then you don't get to do the cool truck guy hood whack!)
'98 K3500 7.4Vortec/4L80E, airbags, gooseneck hitch, Bosch injector upgrade, Magnaflow exhaust, 130K and going strong!
Proud Member: OBS Preservation Society and Hood-whacker Club!
Image resized by Skills:
10-29-2008, 08:20 PM
#8
Flawed Behavior
The cool truck guy hood whack is what puts dents in the front of the hood, even on the OEM steel. If you have an aftermarket coke-can thin hood, you're lucky to not dent it just pushing it closed.
Try gently pushing up and down on the end of it while someone else pulls the cable. If you get it open, lube the inside of the latch with the white grease immediately, do not wait!
Richard
94 C2500LD, 94 3500HD, 98 C3500, 48 Harley chopper
Free beer tomorrow
10-29-2008, 08:24 PM
#9
Once you get it open, take a piece of welding rod or something else that is suitable and connect one end to the hood latch, right where the remote cable attaches. Hide the other end behind the driver's side headlights. Now, if your hood cable ever breaks, you can insert your fingers into the grille opening, fish out your emergency release, and voila!
Hey, even Ferrari's have emergency releases so why not your truck?
10-29-2008, 08:37 PM
#10
Thanks guys. I already have a dent in the hood from someone else whacking it.
However, it seems that the cable is floating around loose. Likely from me not connecting it right when I put the hood back on. I'll try the wire trick cause I couldn't get at it with a screwdriver.
10-29-2008, 09:15 PM
#11
hood wack is what i do on our work trucks cuase the never open on their own ne more
10-29-2008, 09:29 PM
#12
Yeah the hood whack works for me too, but usually all I do is slam the drivers door after I pull the hood release. That jars the hood just enough to pop up. Ha Ha...I love these stupid little quirks.
1996 Chevy Tahoe LT 4x4: Built and Vortech supercharged 5.7 vortec, built Jasper Performance 4L60E, 14 bolt 6 lug 9.5 swap, Hedman headers, gutted cats, dual exhaust, Fastchip computer tune. 12mpg on a good day. SAS soon.
Proud member of the Hood-whacker Club
10-29-2008, 11:15 PM
#13
Hood whack here as well. Don't have to hit it that hard, just a bit to jar it.
'93 ECSB stepside 4x4, 305, 5spd, headers, 3" exhaust with a flowmaster, JET chip, K&N flipped lid.
'00 Nissan Xterra (wifes)
'72 Pontiac GTO, 400/4spd, project.
'05 Honda CRF450R, Fat bars, pro circuit pegs
'01 Suzuki RM125
'03 Kawasaki KFX400, yosimura exhaust, durablue axle.
10-30-2008, 07:42 AM
#14
Flawed Behavior
Why don't y'all shoot some lithium grease inside the latch mechanism before the whack quits working.  Jeez, lazy!
Richard
Free beer tomorrow
10-30-2008, 08:31 AM
#15
Finally got the Dmax!!!
Cuz like everything else on the OBS trucks, if it ain't broke don't fix it! I'm another hood whacker lol. If closing my door doesn't pop it up, a nice half-hearted thud right above the latch always opens it. My bug deflector seems to absorb most of the impact, so no dents here!!
Edit: We should start a "Hood Whacker" club...
NEW TRUCK!!: 07.5 4x4 CCSB LTZ Dmax
Old truck 1992 1500 ECSB 4x4 350TBI-700R4 304k miles
2X member: OBS Hood-whacker Club <-- Join us!!
Tow Pig '95-2500, 454TBI, NV4500, 2wd
10-30-2008, 08:39 AM
#16
Official Smoke Detector
I also use the ol hood whack to pop it open. And to the guy that suggested lithium grease, my latching mechanism is coated in white crap and I can not get it to pop on its own more than about 2 times...
95 350 TBI, transgo shift kit, vette servo, flowmaster, Yukon 4.11's, Detroit TrueTrac, Full 4" RC lift, 4" blocks, 31x10.5 Mud Brutes, Pioneer system...
10-30-2008, 08:45 AM
#17
The hood whack is the only way mine opens.
1999 Tahoe LS 2-Door 4x4 w/ 14 Bolt SF & TruTrac. Corvette 1-2 servo, Gibson cat-back, custom PCM tune by Justin at Black Bear, AD244 alt. upgrade, 4 high headlight mod
Proud member of the OBS Hood Whacker Club
GMT400: Making Mother Nature your b*tch since 1988.
10-30-2008, 09:33 AM
#18
need a bigger hammer
I have the dents in my hood to prove I'm an official member of the hood whacker club! Grease makes mine open for about a week, then I have to hit it again.
98 K1500 'Burb / 2" blocks + TB crank / 3" PA BL / bed-lined rockers and flares / 35x12.50's on 15x8 wheels /
10-30-2008, 11:27 AM
#19
My burb was terrible at this. I have lubed tweaked you name it and sometimes it took forever to get popped.
Couple of weeks ago I stopped and pulled the latch...nothing. Then I decided to move up a little so I started it ad moved ahead a few feet and the hood popped right up. So now that is my new method, pull the latch just before I am stopped.. works every time.
Gary
10-30-2008, 12:11 PM
#20
No room for my brilliance
Smack the hood with your palm - no dents.
My name is William and I'm a hood smacker.
| Thread Tools |
| Display Modes |
Linear Mode
