Old 11-19-2008, 08:08 AM   #1
Axle swap 96 Tahoe - 10 bolt to 14 bolt SF
My 10-bolt was trash, so I got me a 14-bolt SF from a 94 K1500 (or 2500..?)
I've read that I need a conversion u-joint from 1310/1330 to 1350.
The u-joint I've used before has the part # Precision 534G, and that's a 1 1/8" cap diameter, and 3 5/8" wide. (1344??)
Neither the 1310 nor the 1330 will fit the driveshaft, because they are only 1 1/16".
As for the 14-bolt, the 534G diameter is a little small, so the 1350 with 1 3/16" should do just fine..
But can anyone tell me what kind of u-joint I need?
Can't find a match..
Thanks!
ChevyHoe84 is offline
Old 11-19-2008, 08:53 AM   #2
DennisTA15's Avatar
Re: Axle swap 96 Tahoe - 10 bolt to 14 bolt SF
I can't remember which u-joint is correct for the conversion. The 14 bolt I put in my Tahoe is temporary, til I get my Dana 60 in there. So I just swapped the yoke from the 10 bolt and put it on the 14 bolt. They were the same spline pinion.
1996 Chevy Tahoe LT 4x4: Built and Vortech supercharged 5.7 vortec, built Jasper Performance 4L60E, 14 bolt 6 lug 9.5 swap, Hedman headers, gutted cats, dual exhaust, Fastchip computer tune. 12mpg on a good day. SAS soon.
Proud member of the Hood-whacker Club
DennisTA15 is offline
Old 11-19-2008, 09:10 AM   #3
Isn't that a risky operation, as you can alter the pinion preload?
Old 11-19-2008, 09:14 AM   #4
daved931's Avatar
Neapco 2-1153
1999 Tahoe LS 2-Door 4x4 w/ 14 Bolt SF & TruTrac. Corvette 1-2 servo, Gibson cat-back, custom PCM tune by Justin at Black Bear.
Proud member of the OBS Hood Whacker Club
GMT400: Making Mother Nature your b*tch since 1988.
daved931 is offline
Old 11-19-2008, 10:49 AM   #5
DennisTA15's Avatar
It would only be risky if you over tighten or under tighten the pinion nut. I got by with pulling my axles and using a inch pound torque wrench, I measured rotational torque and set it at 10inch pounds. Risky, maybe, but mine is temporary. I did replace all of the seals as well as swap over all of my new 11in drum brakes from my 10bolt, had to reuse 14bolt drums.
If you don't replace the pinion seal then you might as well use the u-joint daved931 mentioned, good find BTW.
Old 11-19-2008, 10:55 AM   #6
02GMCtruck
88GMCtruck's Avatar
Location: Soon to be Albion, Wa, from Pullman, Wa, from Edgewood, Wa
Napa sells the conversion u-joint, That is where I got mine. I know it was a precision u-joint.
Also keep in mind that the 2wd 2500 14SF is 3" narrower than a 4wd version.
Last 3 Stepsides
79 Chevy C10, RCSS/5.0L/TH350/10, 86k. 4/6 drop.
88 GMC K1500, RCSS/5.7L/700R4/NP241/D44/14SF G80, 176k. 9" SAS w/ 35s
02 GMC K1500, RCSS/4.8L/4L60E/NP261/IFS/10, 20k. Sierra HT package: 1 of 234 Trucks.
88GMCtruck is offline
Old 11-19-2008, 11:33 PM   #7
Thanks!
I'll order one from Napa Online if I don't find one here.
That u-joint should be equal to Precision 447 if I'm not mistaken..
Old 11-19-2008, 11:51 PM   #8
02GMCtruck
88GMCtruck's Avatar
Yeah 447 sounds like the one that I bought, now that i heard the number i remember it.
Last 3 Stepsides
