Old 11-21-2008, 07:50 AM   #1
tam
Angry 93 chevy truck skipping and popping codes 32,35,42,54
My truck skips and pops when giving it alot of gas like pulling out or going up big hills. We took of the cat in case that was plugged up. We are pulling our hair out. I am beginning to hate this truck.
tam is offline
Old 11-21-2008, 07:57 AM   #2
Re: 93 chevy truck skipping and popping
Check your timing.
Wouldn't hurt to put a fuel filter on it, and a fuel pressure guage.
89 Camaro, 5 speed, 3.08 LS
kcb37 is offline
Old 11-21-2008, 07:59 AM   #3
tam
Not only does it skip but it bucks me all the way up the hill. At first if I let up on the gas it would stop but lately it keeps doing it. However it doesn't do it all the time, but most of the time. Of course it doesn't do it as much when my husband drives it. He now thinks I'm crazy. Please help.
tam is offline
Old 11-21-2008, 08:32 AM   #4
tam
We did put a fuel filter on it about 6 months ago or less. I called the garage and he said he can't get it in for a week to check the fuel pressure. He also said it could be a hundred different things including the knock sensor.
tam is offline
Old 11-21-2008, 08:41 AM   #5
hornsfan10609's Avatar
Is the truck showing a SES light? If you do check your codes with a paperclip on the OBD port, if not it's more guessing. If your fuel pump is running with enough pressure and your injectors are firing fine, it could still be several other things. Try unplugging the vacuum line to the egr, that would rule out if the egr is at fault.
91 RCSB C1500 4.3 4L60
09 Ford Mustang Bullitt #5998 Brenspeed Tune, LCAs. 13.4 @104.3
94 Ford Mustang SVT Cobra Way too much to list.SOLD 9/4/08
Originally Posted by FordeatinZ71 View Post
i know it's not a Vortec or anything...but i'm happy
hornsfan10609 is offline
Old 11-21-2008, 09:01 AM   #6
tam
the engine light has been going on and off for months. I go about 10 miles before it comes on, but it doesn't always come on after it stutters. I forgot to say that it gets a weird smell when it's doing it.
tam is offline
Old 11-21-2008, 09:09 AM   #7
You need to check to see what codes you have.
You need to jump the two ternimals on the data connector under the dash, the pic below are of my 89 Camaro, but it's the same connector, and the same terminals.
You can see that I just used a short piece of wire, paper clip works too.
Jump the two terminals, then put the key in, turn it forward to run, do not start.
May take a second, but the engine light will flash. Once it starts to flash start counting. It will flash once, pause, the flash twice. Long pause, then flash once, pause, twice, long pause. That is a code 12. It will flash that 3 times, nothing wrong, just means it's in diagnostic mode, so you can read the codes.
Then say you have a code 24, after code 12 flashes 3 times, their will again be a long pause, then it will flash twice, pause, 4 flashes, long pause, and it will repet two more times.
If 24 is the only code you have it will repeat code 12 to show you that it all your codes. Then it will restart with code 12 again 24, 12.
If you have more then one code it will be something like 12, 24, 32, 44, 12.
If so you would then have a code 24, code 32, and code 44.
kcb37 is offline
Old 11-21-2008, 09:52 AM   #8
tam
I just ran the codes they are as follows 12, 32, 35, 42, 54, 12. What do they mean? I know my husband has a book some where but I'm not sure where.
tam is offline
Old 11-21-2008, 10:55 AM   #9
I'm not sure, what then mean, I am pretty sure if you pm Neumannzz he will give you a web page that list them. Don't remeber what it was, or you could search for something like engine codes or trouble codes, he has posted several times, about where to find them.
Or you can wait and someone should be able to tell you.
I would find it for you but my internet is extremely slow right now.
You might try to google it too.
kcb37 is offline
Old 11-24-2008, 09:58 PM   #10
4/6 dropped Silvy on 22s
They have OBD1 books at all parts stores. Just ask them to show you that book, it includes all the codes. The first code 12 is just letting you know the computer is working correctly. The main culprit would be code 32 because it is the first code and that code will bring out the rest of the codes.
I just looked it up, code 32 is EGR valve failure and code 35 is IAC idle air control valve or idle error. I'm guessing it would be your EGR valve or a clogged vaccum line full of carbon buildup,new EGR valve about 45 bucks at the parts store
94 Chevy Silverado 2wd stock 350 green K&N CAI optima red top deleted muffler dropped with 4/6 DJM kit rolling 22" Akuza wheels wrappped in Kumho 265/35/22 tires
95 GMC 2500 2wd longbed 6.5 Turbo Diesel stock 3.73s 14 bolt rear
94stepside5.7 is offline
Old 11-25-2008, 07:37 AM   #11
Dmax geek & Owner...Soon!
gr8shot's Avatar
the code 42 actually will probably be the main problem. That is the knock sensor. Pretty easy to replace yourself, or it should be pretty cheap for a shop to do too. In most cases the EGR shouldn't be causing that problem. the 35 shouldn't cause the problem your describing, but it could make it idle wierd, I'm not real sure about that one. The 54 code could also be your problem. It deals with the fuel pump, so there could be something wrong there.
here's the link to tell what the codes mean.
http://www.troublecodes.net/GM/93_577_tbi.shtml
Edit: I just saw that it doesn't show a code 35... wierd. That should be the IAC valve.
My DD 1992 1500 ECSB 4x4 350TBI-700R4 w/B&M Cooler & temp gauge, 300k. replacement 10 bolt from a '97 OBS
2X member: OBS Hood-whacker Club <-- Join us!!
Tow Pig '95-2500-ECLB-2wd-454TBI-NV4500-G80-150k. the gas hog!
gr8shot is offline
