Old 07-01-2009, 04:55 PM   #1
RIP Jimmy 523 4 LIFE
gwhunter350's Avatar
Oil Change Dilemma.....what to do
Ok so i moved out of the area for work and now im 3 hours away from home. I need to change my oil and i dont have any floor jacks, or ramps here....So how would you all change your oil?
If my lift was on i'd be fine
Im seriously thinking about pulling on to some curb somewhere and changing my oil in a parking lot
Black 2004 Z71 Silverado ECSB,Superlift FIT 6in Lift,35in pc XATs, 18in XD SPYs,magnaflow cat back, AEM CAI, 93 blackbear tune, 5% tint all around, and alot more
Soon to come-Efans(waiting install),cowl hood,4.56s,
RIP Jimmy Hawkins, Im gonna miss you brother
10/16/1989-10/05/2009
gwhunter350 is offline
Old 07-01-2009, 05:00 PM   #2
formerly crewcab06
Re: Oil Change Dilemma.....what to do
I never jack my truck up to change the oil. i just slide a pan under there, reach under and undo the bolt, then while thats draining I change the filter. All your gotta do is watch for the hot exhaust.
I have cranked the t-bars only bout 1.5" in front, and I have some mud terrains (285/75/16) so i assume it sits just a lil bit higher, but not much.
Oh and I'm 6', 207 lbs and I can still squeeze under it. Its a waste of time to get out the jack and stands for me...
My build thread
http://www.fullsizechevy.com/forums/...ld-thread.html
1LOW4X4 is offline
Old 07-01-2009, 05:33 PM   #3
OBS 4X4 HOE!
bai78's Avatar
I have never jacked my truck up to change the oil. Like posted above, I just slide under there & drain the oil. There was never a problem fitting under there before the lift with stock 245's on there. The 285's made it easier, & of course the 6" lift with 315's makes it a breeze.
1999 Tahoe LT 4x4
- 6" Pro Comp Lift, 315x75x16 ProComp A/T's on 16x10, SSBC Force 10 brakes, 4.56 gears, true trac, Doug Thorley Tri-Y headers, Borla dual exhaust, ProCharger, BBP in PERSON Tune, 255 HP intank Walbro.
bai78 is offline
Old 07-01-2009, 05:34 PM   #4
www.subsonickustomz.com
ikon's Avatar
just lay under it...thats all i do haha
.:Subsonic Kustomz Minnesota Prez:.
ikon is offline
Old 07-01-2009, 05:37 PM   #5
has a truck
kirknd4spd's Avatar
When my truck was stock height I could easily fit under it to change the oil without jacking it up or putting it on ramps. It was actually easier to do then than it is now, because now I have to prop myself up at an awkward angle to change the oil.
For sale: 3.73, 2" blocks, 5.13
kirknd4spd is offline
Old 07-01-2009, 06:07 PM   #6
Tweaks's Avatar
Unless it's lowered or 2wd, you ought to be able to crawl under there no problem. Ramps are nice, but not necessary for a 4WD truck like yours.
00 RCSB Z71 / ss Spintech exhaust / Z71 Tahoe valance / EBC slotted&drilled brake rotors / Edelbrock headers / Blackbear tune/ 6000k HID low beam and fog lamps / Auto-headlight mod(nice)/ Vette servo
Wish List: E-fans
My allergies to these fans... has returned-Slapshot
Tweaks is offline
Old 07-01-2009, 06:17 PM   #7
Urban Cowboi
rebelbowtie's Avatar
yea i have never jacked up a truck to change the oil. even my 92 2wd
Thanks xZoomerZx
rebelbowtie is online now
Old 07-01-2009, 11:22 PM   #8
Can I help you?
ksukats57's Avatar
Shouldnt need to jack it unless its lowered?
2001 k1500HD Sierra ccsb SLT, Lq4, 4l80e, 14 bolt SF, dual Flows, BlackBear tune
67 C10,283v8, all original with 86000 miles!
ksukats57 is offline
Old 07-02-2009, 12:20 PM   #9
At work we have a raised sidewalk around the building. When I change the oil here, while I'm already dirty, I just do the sidewalk / curb thing.
2002 Tahoe LS • 5.3 Flex • Corvette Servo • AVS In-channels • JVC KD-PDR80 • Tricked out cigarette lighter knob
1984 3500 3+3 Crew Cab • 350 w/Edelbrock 600• 700R4 w/Corvette Servo & manual TCC • AVS Surface Mount • JVC w/Sub • Cloth w/Captains' Chairs
Grebbler is offline
Old 07-02-2009, 01:41 PM   #10
just drive up on a 4 inch block of wood. That is what i do cause i have the nerf bars on the truck which get in my way.
Nova Scotia Canada
1999 ecsb 1500 silverado LT 4x4
1991 Cavalier Z24 - needs TLC
1972 Chevelle - Have to finish
Seymour is offline
Old 07-02-2009, 03:22 PM   #11
I dont like just sliding under there cause i feel like everything is right in my face, im getting ready to curb it and change it now lol
Old 07-02-2009, 04:33 PM   #12
REAPER CREW
TheBigBlackHD's Avatar
Hendrick Pre-Owned changes mine
But i used to just crawl under it
That aint sh!t, hold my beer...
Courtsey of 04NCZ71
MY BUILD THREAD
NC BLACKBEAR TUNE MEET
TheBigBlackHD is offline
Old 07-02-2009, 04:37 PM   #13
F4MOU$'s Avatar
Take it to get done That's what I do. A normal oil change cost me 19 dollars, synthetic cost me like 50 and thats a full oil change with topping off all the fluids and an over look.
♠ Dumped Magnaflow ♠ Rough Country 3" ♠ 33 x 12.50 Cooper STT's ♠ Blackbear ♠ K&N ♠ Keystone Hood ♠ Carriage Works Grille ♠ Painted Handles ♠ 6000K HID's ♠ 35% Tint ♠ 17x9 XD Hoss's ♠ Bedrug ♠ Smoked Tails ♠
F4MOU$ is offline
Old 07-02-2009, 05:03 PM   #14
like a rock
I fit under mine.
1994 ECSB K1500 F44 Z71,GT4 Broken G80, LO5 with spacer, ultimate TBI mods, intake,AFPR.
2" crank 2" blocks 295/75/r16 General Grabber AT2's
2000 Nissan sentra 26 MPG all city.
dsponder is offline
Old 07-02-2009, 07:05 PM   #15
FSC Road Warrior
ntimidator_3's Avatar
i pull mine up on ramps just to get the pan angled back to drain better
2004 Silverado 2500HD 4X4, reg cab Long bed. 235000 miles and counting.
Thanks for the sig 454SS
ntimidator_3 is offline
Old 07-02-2009, 07:30 PM   #16
AndyTblc's Avatar
I put mine on ramps and use all the extensions I can get, I never just crawl under it, as I'm very claustrophobic and do not like being under vehicles at all.
1999 GMC Sierra Classic 1500 4x4 Z71- 5.7L 350 V8
AndyTblc is offline
Old 07-02-2009, 07:44 PM   #17
Turn and Burn
just crawl under there I did it on my 88' 2wd lowered truck wit hjsut sliding under it.
Thanks xZoomerZx
1995 GMC 4x4, 350, w/A/T's,3.73's,Debaged, Heddman LT's w/ Thunderbolt cat and Thrush muffler, TB & Inj. spacer, Big 3 Upgrade, Ultimate TBI mods, AFPR, U D pulleys
5200 lbs. at 14.0MPG
1988 GMC SOLD
1988 GMC 355 is offline
Old 07-03-2009, 02:43 PM   #18
I got it done, i just found a parking lot with those little concrete stop things at the end and pulled up on that. It worked really well, I tried to just lay under but it dont work for me, i cant stand everything in my face, the cats are hot as fvck and i feel cramped.
Oh and the synthetic oil change here is 89.99 plus BS shop fees so prob like $100...no fuvking way im paying someone $65 in labor for 15min of work
Old 07-03-2009, 02:48 PM   #19
Urban Cowboi
why are your cats hot when you are changing the oil? i usually change mine when the engine is off
Thanks xZoomerZx
Old 07-03-2009, 02:57 PM   #20
cause i now have a gravel driveway so i drove to an area where i could change it with out laying on gravel
