Old 07-03-2009, 07:23 PM   #21
DUH! Big Red Truck!
GreaseDog's Avatar
Re: What Have I DONE???
Originally Posted by Heslekrants View Post
That one on the right is what mine looked like when my tranny went. I paid $1,800 for a rebuild with all the HD goodies inside.
same here. cant complain about it one bit though. 10K on it now, and was worth every penny.
GreaseDog is offline
Old 07-03-2009, 07:36 PM   #22
mgmZ71's Avatar
Re: OH NO - What Have I DONE??? (Stump pulling mishap -- tranny?)
Spent $2000 on my 4L60E and it proved to be VERY durable even after over 100,000 miles. I used the hell out of it and up to the point when I sold the truck, the firmness never weakened. Same will be done on the 03 when it decides to go, hopefully not for a little while.
D/D 03 ecsb Z71-6"RCX, AAL, 16x10 Pro Comp wheels, 315's, p/p heads, Comp 918 springs (thanks to GM's great Castech heads), P/P TB, Intake, Exhaust, custom tune.
mgmZ71 is offline
Old 07-04-2009, 02:17 AM   #23
Fool Injected
FordeatinZ71's Avatar
yea, you toasted it. i guess you know now...NEVER pull heavy loads in 4Hi. you could find a junkyard transmission cheap i'm sure...but you get what you pay for. i've heard good things from people who've used Bowtie Overdrives transmissions...or you could have a local shop build it. good luck with the wife...
FordeatinZ71 is offline
Old 07-04-2009, 08:19 AM   #24
Big Daddy
1-8-4-3-6-5-7-2's Avatar
Originally Posted by SQLHAWKN View Post
put it in 4hi - reverse - gave it some gas -
Reverse? Why reverse? You have a 3.059 1st gear ratio and a 2.294 reverse gear ratio.
1996 K1500 Suburban. Black Bear tune, 14 bolt SF, add-a-leaf, new take-off wheels, cowl hood.
1-8-4-3-6-5-7-2 is offline
Old 07-04-2009, 11:54 AM   #25
Because 4 High means 4x4 High power.
Chev-350 is offline
Old 07-04-2009, 11:56 AM   #26
hornsfan10609's Avatar
Same story here, 1800 for a rebuild of my 700R4 with upgraded internals ('vette servo, HD sunshell, etc. etc.). Be sure if you get it rebuilt the shop uses only AC Delco or better parts.
91 RCSB C1500 4.3 4L60 Cash for Clunkered 8/3/09
09 Ford Mustang Bullitt #5998 Brenspeed Tune, LCAs. 13.4 @104.3
94 Ford Mustang SVT Cobra Way too much to list.SOLD 9/4/08
hornsfan10609 is offline
Old 07-04-2009, 01:29 PM   #27
if you have any mechanical inclination, you can pick up another one for under $200 from a local junkyard or probably craigslist and just put it in. Or, have that one rebuilt and do the swap yourself to save on labor. I have already said that I will rebuild my tranny only once, when it goes again, I fully intend to get a T56 F-body 6 speed. Similar gears, and a way better overdrive ratio (0.64:1 hell yeah)
hotdogstand is offline
