Old 10-28-2009, 10:20 PM   #1
popping issue from driver side
I have a 98 c1500 reg. cab... i've changed upper and lower ball joints on both side's and also inner tie rod end on driver side, but i still have a popping sound. when i hit a bump or turn the ball joints are in there good i just cant figure out whats still popping. my outter tie rod end was lose at one point idk if it could have went bad. Thanks in advance
98_chevy is offline
Old 10-28-2009, 11:38 PM   #2
armystud999's Avatar
Re: popping issue from driver side
Sub'd I got the same issue. Its not a loud popping just slight on mine.
97 Yukon 2dr, 6" lift, 35 toyo open country M/T, 4.56, Yukon Locker, Black Bear Tune, Flowmasters, WAY too much to list...
03 Honda CBR 954RR Custom paint, chrome, stretched.
05 Honda TRX 450R Stock
70 Chevy C10 Short bed "Restored" **SOLD**
72 Chevy C10 Long Bed**SOLD**
armystud999 is offline
Old 10-28-2009, 11:53 PM   #3
It not loud I just don't want something to happen
98_chevy is offline
Old 10-29-2009, 12:03 AM   #4
CV Shaft
tss212 is offline
Old 10-29-2009, 08:56 AM   #5
Supporting Member
para driver's Avatar
I just rebuilt my front end and had the same problem. Turns out the shock mounts were a little lose. You have to tighten them up really strong. See if that helps?
para driver is offline
Old 11-05-2009, 01:03 AM   #6
I tryed to tighten the shocks they want tighten no more then they are the one on the the driver side is higher then the other could that be a bad shock? Do bad or loose shock make a popping sound?
98_chevy is offline
Old 11-05-2009, 11:30 AM   #7
Supporting Member
mine popped and rattled a lot until I tightened them up, tighten ALL 4, tops and bottoms.. the sound may not be coming from where you think it is??
Old 11-05-2009, 12:09 PM   #8
You can feel it no the driver side I thinks it's the shock cause it won't tighten on the top
98_chevy is offline
Old 11-05-2009, 09:46 PM   #9
Supporting Member
I layed on the garage floor and had my son gently rock the bumper, I could hear it clicking, and could see the upper shock bolt moving slightly.. if it won't tighten it might be stripped or rusted, try replacing the bolt and nut and use loctite.. it makes a lot of difference in the ride quality.
Old 11-06-2009, 12:47 AM   #10
bigkuntry08
i got more of a quiet clicking noise in my chevy and its a broken cv axle
bigkuntry08 is offline
Old 11-08-2009, 08:28 PM   #11
tightened my shocks they were loose but still have a popping
98_chevy is offline
Old 11-08-2009, 08:34 PM   #12
I owned a Ford.....once
stupid friend's Avatar
Originally Posted by tss212 View Post
CV Shaft
c1500 is 2 wd it doesn't have cv's. Mine was doing that after I rebuilt the front end, come to find out it was the lower shock bolt not tightened enough. Jack up the front end, on jack stands have someone take a 2x4 under the tire, and bounce the tire up and down. Feel around for something loose.
stupid friend is offline
Old 11-08-2009, 09:50 PM   #13
bigkuntry08
wow lol thanks stupid friend did not even see the c1500 sry for being an idoit next time ill pay closer attention.
Old 11-09-2009, 08:17 PM   #14
we'll let it slide this time.
