11-04-2009, 06:54 PM
L31 motor swap computer question
if i had a 305 5.0 and i wanted to swap to a 350 5.7 what needs to be done with the computer? would pulling a computer out of a truck that came with a 350 be plug and play?
rcsb 98 5.7, 2wd, shorty headers, whipple charger w/aux injectors + whipple computer, FIPK, underdrive pulleys, msd coil, e-fans, BUILT 4L60E, 3.42's unlocked, hypertech programer...NEED to get custom tune w/4.10's locked,cam and 3" exhaust hahaha
11-04-2009, 07:14 PM
#2
Re: L31 motor swap computer question
Yes as long as the donor has the same specs. trans,diff ratio etc. and don't forget if you switch you will have to do a passlock relearn. If you don't have the correct cals in the 350 PCM use the 350 PCM and have it flashed or a custom tune. But by all means use the 350 PCM for your 350ci as the knock module in the PCM is different.
11-04-2009, 07:25 PM
#3
I you just want stock 350 performance, it'll run fine on the 305 tuning.
RandyW
'02 Short Bed/ Reg Cab/ LS1/SS wheels,3.73 Gears
'96 Tahoe 2dr 4x4
11-04-2009, 07:33 PM
#4
Just be careful as you are running a supercharger. Running a 350 on a 305 tune wouldnt cause problems naturally aspirated, but with the supercharger any lean issues can cause trouble very quickly.
The Vortec 305 trucks run a smaller single cat exhaust where the Vortec 350 in the 1/2 tons runs a dual cat exhaust with 1 7/9" headpipes that connect the manifolds to the cats. The 3/4 ton and l;arger L31 350 applicatons use a larger 2 1/4-2 3/4" headpipes with even larger cats.
The Vortec 305 uses 3 precat and 1 post cat O2 sensor while the L31 Vortec 350 uses 2 precat and 2 post cat O2 sensors. because of this a Vortec 350 tune may cause issues.
Since you are running a Whipple, I suggest you get an in person tune. the auxillary injectors do provide protection against lean conditions.
peace
Pauly
11-04-2009, 07:34 PM
#5
Yes running lean and with less timing.
11-05-2009, 08:11 AM
#6
Sorry, didn't notice the booster, I would custom tune with a s/c for sure.
RandyW
'96 Tahoe 2dr 4x4
11-05-2009, 03:45 PM
#7
peace
Pauly
pauly,
so you suggest i stick with the 305 computer and get a custom tune right? i was planning on getting a dyno tune after the swap and gettin full custom 2 1/2 or 3" exhaust piping dual cats and x pipe. would that work alright?.... but how do i fix the o2 sensor placements from the 350 to 305? also what about the 305 and 350 having different knock modules...i didnt know they were different
Reason: forgot a question
11-05-2009, 03:49 PM
#8
also if i remember right i onlt have 2 pre cat sensors and 1 post cat...
11-05-2009, 04:25 PM
#9
pauly,
On e the cover of the modules there are diamond shaped covers with screws just exchange them.
11-06-2009, 07:49 PM
#10
ok thats easy enough but what about this deal with the o2 sensors? is there any way i can fix that problem using the 350 computer? i would also have a problem with the geal ratios being different from the trucks...i have 342's and the donor truck have 373's...and i dont think this matters but the donor truck is a 97 and i have a 98....anyone see any problems with that?
| Thread Tools |
| Display Modes |
Linear Mode
