Go Back   FSC Forum > General Discussion > Tow/Haul Mode
Old 09-27-2009, 08:07 PM   #21
021500HD's Avatar
Re: 1500 hd
Unless you are doing some kind of tractor or some other kind of pulling other than towing, you'll probably have no problems.
Leo Paugh
96 Tahoe 4dr 4x4
02 1500HD pickup 4x4
86 MCSS
021500HD is offline
Old 09-27-2009, 08:26 PM   #22
94_c/1500's Avatar
Re: 1500 hd
This thread was about a 1500 HD. Not about which is the best axle. My question was why did they make a semi floating 14 bolt? As far as the semi floating being stronger than the full floating, the full floating is stonger in design and GM could use stronger parts. It just makes sense to start out with a stronger axle and then add stronger parts.
1994 GMC Sierra, 1982 Jeep Scrambler, 1975 Jeep J10
Drive a pickup truck, trustin' God and luck
http://www.fullsizechevy.com/forums/...my-trucks.html
94_c/1500 is offline
Old 09-27-2009, 08:54 PM   #23
Everyday I see my Dream!
Orangette's Avatar
Re: 1500 hd
Cause GM doesn't Give a **** about how strong it is. They just wanna Sell trucks and do it the Fastest,easiest and less costly way.
-Josh
1994 Silverado RCSB, 350 Swap, Vortec Heads, XE268H
1987 F150 RCLB, 302, Dart Heads, Cam, Cobra Chip
1970 Pontaic LeMans, 455 Buick Swap, TH400,12Bolt
Orangette is offline
Old 09-27-2009, 08:58 PM   #24
Supporting Member
94383Z71's Avatar
Re: 1500 hd
jesus dude
they are both very good axles, and 14 bolt sf vs ff, ff is stronger. But for those who don't want hubs sticking out, the sf is still a great improvement over their 10 bolt IMO
Parts, Dmax Rebuild
94383Z71 is offline
Old 09-27-2009, 10:37 PM   #25
DUH! Big Red Truck!
GreaseDog's Avatar
Re: 1500 hd
if you're so worried about strength, why did you buy a truck that has the absolute bottom of the barrel drivetrain in it?
GreaseDog is offline
Old 09-27-2009, 10:40 PM   #26
94_c/1500's Avatar
Re: 1500 hd
This thread is not about my truck, I hope you can comprehend that.
Old 09-27-2009, 11:18 PM   #27
DUH! Big Red Truck!
GreaseDog's Avatar
Re: 1500 hd
i comprehend that just fine. you're ranting and raving about strength, and you're driving a truck with the weakest drivetrain GM puts in a fullsize truck.
kind of ironic isnt it?
Old 09-27-2009, 11:24 PM   #28
94_c/1500's Avatar
Re: 1500 hd
guess so
Old 09-27-2009, 11:24 PM   #29
94_c/1500's Avatar
Re: 1500 hd
it seems you are also ranting and raving
Old 09-28-2009, 12:09 AM   #30
Orangette's Avatar
Re: 1500 hd
he is stating facts!
-Josh
Old 09-28-2009, 01:55 PM   #31
Supporting Member
94383Z71's Avatar
Re: 1500 hd
I dont even see the point in the thread anymore
Parts, Dmax Rebuild
94383Z71 is offline
Old 10-03-2009, 09:27 AM   #32
Can I help you?
ksukats57's Avatar
Re: 1500 hd
Back on topic.....
The 1500hd is very similar to a 2500hd with a 6.0. Some of the only differencs are, yes, the rear axle, and the the 2500hd sits higher and has a different front clip. The 1500HD also has the automatic transfer case, which I dont believe the 2500hd has. I believe there are also a few minor differences in the front suspension. The 1500hd has hydroboost and most other heavy duty features found on the 2500hd
2001 k1500HD Sierra ccsb SLT, Lq4, 4l80e, 14 bolt SF, dual Flows, BlackBear tune
67 C10,283v8, all original with 86000 miles!
ksukats57 is offline
Old 10-07-2009, 09:52 PM   #33
JeffsJeep04's Avatar
Re: 1500 hd
The 1500HD is exactly the same as the regular 2500, as already stated. To answer the question, the reason for the SF axle is $$. It's much cheaper to manufacture a SF axle then a FF axle. This is passed onto the customer. The vast majority of people don't need a FF rear axle, so they are saved for the HD trucks. I'd say a good number of the guys with the HD trucks really don't need the strength they have, but if they want to buy it, it's their money.
1999 GMC Sierra RCSB 4.8L, NV3500, 3.73, 4x4, 120k
2002 Trailblazer: Wifemobile with matching paint and Trifecta Tune
1989 Jeep: little of this, little of that
JeffsJeep04 is offline
Old 10-11-2009, 08:22 PM   #34
021500HD's Avatar
Re: 1500 hd
as was pointed out by Stacy David on Gearz this weekend, the 14 bolt has the center support for the pinion to ride in like the 9 inch ford which makes it strong, do both 14 bolts have this feature?
Leo Paugh
96 Tahoe 4dr 4x4
86 MCSS
021500HD is offline
Old 10-12-2009, 08:01 AM   #35
Re: 1500 hd
No, only the FF version.
Old 10-16-2009, 09:03 PM   #36
jocww's Avatar
Re: 1500 hd
This is why I like my 2500hd duramax I can pull a freight train I like to call my 24 ft enclosed and not worry about breaking ****. You can put this as a useless post hahaha.
02/04 z71 tahoes, 02 duramax allison ccsb, 65 elcamino, 56 Belair, 49 5 window truck
for you myspace people girlscuddlebug69
jocww is offline
Old 10-26-2009, 10:22 AM   #37
Re: 1500 hd
dosent the HD package include an auxilary oil cooler too?
2004 1500 5.3 standard cab long box Z85
Stupidity is the number one sin
jro909 is offline
Old 10-26-2009, 10:45 AM   #38
TanTahoe's Avatar
Re: 1500 hd
2500HD do come with the push bottom 4x4. The only ones ive seen that have the lever is the 8.1L woth the Allison, even then Ive seen a few 8.1L/Allison with push button.
If they put a FF in the 1500HD why make a 1500HD? Thats one of the point to buy a 2500HD, for the FF.
Freedom Isn't Free
TanTahoe is online now
Old 10-26-2009, 10:45 AM   #39
FSC BOT
V6rado94's Avatar
Re: 1500 hd
1500hd = 2500ld
Dubbed FSC BOT by: WildChevys
V6rado94 is online now
Old 10-26-2009, 01:47 PM   #40
94_c/1500's Avatar
Re: 1500 hd
Originally Posted by V6rado94 View Post
1500hd = 2500ld
almost, but they are not the same truck
