10-20-2009, 09:38 PM
#21
Re: Buying a 1500
SO I found a 2005 black single cab 2WD 5.3 with 32,000 miles I talked to the dealer he will let it go to me for $13,000 out the door. THe GM Build sheet says 3.23 Axel Ratio, 5.3 295HP iron BLK V8, HD AUX TRANS cooling system, G80 locking diff, I hope this is enough to pull 5,000 pounds 3,285 mils home =)
I am still debating on this truck it is a 6 hour drive to get it...
10-21-2009, 06:57 AM
#22
345 Horse Hemi Killa
Re: Buying a 1500
well, even though its a reg cab 2wd, 3.23's are going to suck pulling anything at all, but if the price is good and you like it, i say good luck.
2006 Chevrolet Silverado Ext. Cab Vortec Max LT3, 6.0(LQ9), black, K&N intake,
40 series Flowmaster, Line-x bed liner. SS Instrument Cluster, Corvette servo.
Leveled with 295/70/17 Terra Grapplers.
93 blackbear tune.  1996 Saturn sl1 5spd 4cyl. 100hp of pure aggression
10-21-2009, 03:53 PM
#23
Re: Buying a 1500
Yeah I know 3.23's do suck but I feel its a good price... how much would it cost to get the gearing changed?
10-21-2009, 09:40 PM
#24
FSC's Resident Banker
Re: Buying a 1500
It'll cost you about $500 or so to get the gears changed. The 3.23's will pull your S2000 just fine. Do not put it in OD...leave it in D and Tow/Haul on. Keep your speed down...maybe around 70. It'll be turning about 2600 RPM's in D @ 70 mph, that should be right in the powerband and yield good power and decent mileage (for pulling 5000 lbs.)
As some guys have mentioned earlier, what are your plans for the truck when you get to Cali? If you plan to just drive it without pulling big loads all the time or putting 20" wheels on it, the 3.23's will be fine, because it'll yield better fuel mileage. If you plan to pull a lot or put larger wheels you might want to think about going to 3.42's or 3.73's in the future.
Sig courtesy of: ilikedirt
2002 Chevrolet Z71 ECSB LT, 305/70-16 MTZ's, 3" BL, Flex-a-lite 292 E-Fans
10-21-2009, 10:19 PM
#25
Re: Buying a 1500
I appreciate that good info and no I do not plan on towing anything after this big move. I want to get a 17ft bass boat eventually but not for at least another year or so lol
10-21-2009, 11:29 PM
#26
Re: Buying a 1500
I have a 2007 NNBS with the 4.8 with the sucky 3.23 gears.
I have made several trips to the dump, and while it does start off slow its not to bad. Heaviest load to the dump 5300 pounds. Just leave the tranny in drive or 3rd gear, and you'll be about 2400 rpm doing 70mph. That will give you enough power to take any hill with that much weight.
Since Les is quitting the show I emailed the producers and hopefully I'll be next.
10-24-2009, 03:20 PM
#27
Re: Buying a 1500
It was a 42hours of hell and back but I got my truck and I couldnt be happier everything I want and more...
10-24-2009, 04:26 PM
#28
Re: Buying a 1500
Sweet ride!! I've always like the SS wheels on a RCSB truck. I've got a friend with a 02 RCLB, black like yours. He's running a Magnacharged 5.3L, 4L65E, & 3.73's...goes consistant mid 12's and gets 20 mpg with it.
10-24-2009, 04:54 PM
#29
Re: Buying a 1500
THANKS I dont really want to mod it any times soon... I would like to get a shorty antenna and a HID system for it eventually
10-25-2009, 12:28 AM
#30
Re: Buying a 1500
great looking truck.. I am glad that you were able to find something that you liked. Enjoy the truck
05 Silverado 5.3, Whipple  , Nelson tune, JBA Shorties, 80mm BBK Throttle Body, 6" Tuff Country lift, 325/65/18 Toyo ATs, Avic D3 with 2 small 8's
10-25-2009, 12:40 AM
#31
....used to have a 2 door
Re: Buying a 1500
Was that grille modified for the HD hood to fit it, or do they just fit that well already?
2001 C3 6.0 AWD, 3/4 drop, DDU grille, Volant intake, flowmaster exhaust, pulleys, 05 e-fans, shaved tailgate handle, rollpan...tuned by ME.
2003 Tahoe Z71 5.3L, Silverado clip
1995 K3500 SRW..L31, 4L80e, 14bff
10-25-2009, 01:24 PM
#32
Aggie Class of 2012
Re: Buying a 1500
thats a nice looking truck and sounds like you got a good deal on it
also thank you for your service!
'98 ECSB Z71 DC lift with 35 MTZ's and yukon 4.88s Kappa 6.5's and 6x9's PG 600.1 PA LT 960 2 10" Assassins sold
new truck- '04 Silver CCSB lt z71 5.3l 3.73
10-25-2009, 10:27 PM
#33
Re: Buying a 1500
I have no idea I am just starting to learn about trucks. I grew up on imports this is my first V8 sorry =) I didnt even know it was an HD hood until you said it lol
10-25-2009, 10:29 PM
#34
Re: Buying a 1500
What I want to do is a rear disk conversion I can not believe vehicles espically trucks are still equipped with drums. How much does it cost in parts and where can I get an oem set up?
10-25-2009, 10:32 PM
#35
Re: Buying a 1500
There really isn't any need to go to the expense of doing a rear disk swap. It will make it stop a little better but actually GM went back to drums and put bigger brakes up front and they stop better then the 99-04 NBS
10-26-2009, 08:56 AM
#36
Can I help you?
Re: Buying a 1500
Yeah they went to drums because it was cheaper and they could do it without sacrificing braking performance.
2001 k1500HD Sierra ccsb SLT, Lq4, 4l80e, 14 bolt SF, dual Flows, BlackBear tune
67 C10,283v8, all original with 86000 miles!
| Thread Tools |
| Display Modes |
Linear Mode
