It's my impression you need to take at least one valve cover off to get the intake out..
If I did it again, I'd pull all the accessories and the fan shroud first so I could climb in. Get everything off the intake. Pull the valve covers, pull the intake. Exhaust manifolds. there are head bolts hiding down there, so I loosened all the bolts I could from the exhaust manifolds to the crossover pipe to get clearance. I believe I had two different size nuts here too, which was slightly confusing. I wish these would come off though, I'd like to paint them with at least some barbeque paint or something while they're off the engine.
If I recall correctly, my mount for the PS Pump / Alternator had four bolts and one stud on the engine. Two of the bolts were right next to each other down low into the block itself. (Took me a while to realize there were two back to back). Another was visible but behind the PS Pump. The last bolt and the stud were around the top left.
I don't know if my configuration is weird. It was a state government burb originally, so maybe they had a heavy duty alternator that required a different bracket, but I definately had to remove the PS Pump pulley to get this off. The bolt I pointed out in the earlier picture (in the blue rectangle) had to be pulled clear out for the PS Pump to drop.
I removed the rocker arms, but I should have loosened them and only pulled out the rods. Almost everyone said to keep track where each part came from, so I did that with nice engine looking cardboard box.
Unbolting the heads took forever going through the pattern 1/4 turn at a time. The worst was breaking the bolts initially though. I didn't have a breaker bar so I was using a wrench on the end of the ratchet and that was fun everytime they finally turned.
My passenger side head had a ground wire bolted to the back side too.
When I took out the back bolts on each side that were below the exhaust manifold, coolant came out. I'm not sure if this was normal, but all my gaskets were pretty much cooked anyways.
I was planning on tapping the head gasket and intake manifold bolt holes. Is this a bad idea? I found a thread discussing it but there seems to be no conclusion:
intake manifold gasket....part deux.
Same for the spark plug holes, the front two plugs were really tough coming out, I had to leave them in the heads until I got them off. Does anyone know what size this is? My set is too small.
I've got the engine drained and I'm planning on flushing it out for now with diesel and then getting the residue out with some parts cleaner. Does this sound reasonable?
I also think I mucked up the marks I made on the distributor. I'll need to figure out that whole mess when I get back that far.
