Hey fellas, Ive got a lot of questions here so bear with me. Im sure this has been covered in one form or another but I cant find exactly what Im looking for. My truck is a 1990 C1500 4.3 tbi v6 with a 5 speed. I have got my hands on a 2002 complete dropout LQ4 6.0 and 4L80e trans. SOOO... im trying to figure out how to go about this whole thing. A BIG part is figuring out engine mounts to go from the dinky little 4.3 to the Gen 3 V8. THEN, taking all mileage and personal preference out of it, will it be an EASIER and CHEAPER swap to stay fuel injected or go carb? its registered antique so worrying about emissions goes out the window.
I know with the carb I can re use my throttle cables and cruise control cables. Also, the little MSD box makes wiring the engine to start and run very simple. Also Im assuming if I use my original oil and temp sending units, my gauges will still work too. Also can I use my stock fuel system with a pressure regulator to feed the carburetor? How would the 4L80e be controlled? How would the speedo work?
if I put all the fuel injection components back on. I know I will need to change up the fuel side of things first off. I will also need the ecm tuned. How would my cruise control work? I dont really have a clue as to how I would wire this up so that everything continues to work properly like air conditioning and the like. Im guessing the factory computer from the gen 3 engine would run the transmission but still unsure of the speedo?
