4l80 in 73-87? Who's got one?
jdstephens
New member
Aug 5, 2006
142
Florida
#4
Re: 4l80 in 73-87? Who's got one?
well, whoever get's theirs in first, post some pics. I won't have mine in my 86 until June, along with a 6.0 ;)
bitchin'!
jdstephens
New member
Aug 5, 2006
142
Florida
#6
I am buying it off a guy on 67-72trucks forum.
05 6.0/4l80 supposed to have 5 miles...he got it from schram off ebay awhile back. $3500, but it won't make it to my house until June...
Jan 16, 2006
17
Gretna, NE
#7
I have one installed in an 86 C10. This is with a regular SBC, not an LS series. I used the original crossmember and added a "tongue" with some C-channel for the trans mount. I had to notch the front a bit to clear the trans pan. The last pic is why I went with the 4L80E....
Edit: the crossmember is in the furthest back set of hole (for TH400's).
EWC
New member
Dec 9, 2007
79
Beltsville , Md
#10
I'm doing one as well . Moved the crossmember back like 3 1/16 " , from the TH400 holes , made some careful measurements and drilled new lower holes . Mine is an 85 CC Dually and has the upper braces for the crossmember . The frame is narrow enough that a right angle drill is tough to get in there so I used aircraft drill bits that are 12 " long . Ran them up thru the new lowers and drilled the top holes . The upper holes are not in line with the lowers so I used plenty of WD40 to lube the lower holes .
Mar 18, 2007
939
houston
#11
well i did the entire swap and then some...
i just made a x-memember for 20 bucks. i have a welder, chop saw, and the idea. its 2x2 16 or 14 gauge square tube. it doesnt hang down like the factory piece, and its easy as heck to make.. took about 10 minutes or so.
clint
EWC
New member
Dec 9, 2007
79
Beltsville , Md
#13
I'm trying to run a 91 RV 1 ton diesel harness with a 95 G van diesel ECM . Trans is out of the 95 G van diesel and the 91 RV harness , with the electronic speedo , should work .
GreaseDog
Active member
Dec 20, 2004
16,157
40
Elkhart IN
#14
modular93fox, you might considering adding some side plates to that crossmember. i have seen crossmembers built like that break the two welds you have hold ing the rear of the trans up.
Jan 16, 2006
17
Gretna, NE
#15
I'm planning to build a simple controller for the trans. I'm planning to shift it manually via steering wheel mounted buttons. Line pressure and TCC will be controlled by MAP pressure. No automatic shifting, at least for a while.
Mar 18, 2007
939
houston
#18
ah, you guys dont know what your talking about ... haha, just kiddin, since 2 of you guys mentioned it i will take a gander this weekend and see what i have laying around the garage. thanks for the heads up.
i got some 1" by 1/8 flat bar i could lay over the weld (after i ground them down) and weld the flat bar over that? or are you talking about putting a piece of plate stock over the entire 2 pieces?
clint
