5 lug 14 bolt sf from a 1990 454ss
jmig
Member
Aug 1, 2005
913
57
maryland
I put her back together yesterday with the repair bearings, new pinion seal and a rear diff gasket and 3 quarts of synthetic gear oil. I decided to put her up for sale and use the $$$ on air ride parts I am gathering.
I spent $300 for the rear and another $325 on bearings, seals, gasket, gear oil, new backing plates and paint not to mention the time I have in it to clean it all up as you see it pictured.
jmig
Member
Aug 1, 2005
913
57
maryland
#2
Re: 5 lug 14 bolt sf from a 1990 454ss
A few progress pics in case anyone is interested. The day I brought it to the shop...
...started by cutting off the half ass bag brackets and cleaning out the old gear oil...
...then used a needle scaler and cup brush to clean it down to bare metal...
...then three coats of primer...
...and the final product with three coats of flat black and the new backing plates.
Apr 13, 2008
6
al
#8
This axle assembly is almost a direct replacement for obs Truck and SUV 10 bolts. You can use your 8.5" yoke on the 9.5" rear to retain the smaller u-joints, or you can use a conversion u-joint. You will need larger u bolts to attach the 9.5 axle housing to your leaf springs. If you will post a price it may help your sale.
free bump
jerry
jesse82nc
Lifetime Gold Member
Feb 25, 2013
223
Clayton, NC
#14
Just saw in MD. What are you asking for it anyway?
Edit:
Hah, guess I should have read all the posts. Going to PM you
-Jesse '96 C1500 5.7L 2WD
