RC 4.5 in lift kit.
Mar 30, 2016
3
Auburn, AL
I have a 2002 2wd 1500, and in a month or so i will be putting it on the 4.5 inch lift with 33 toyo mts. i have the the 1.5 in leveling spacers currently installed but have read the truck will still sit a littler lower in the front with the 4.5 inch kit. should i keep the spacers and add them to the coils on the 4.5 inch lift or leave the lift as it is. looking for someone who has the 4.5 inch kit to see if u think i should add the spacers. will post pics when it is done.
Nov 26, 2006
431
Chandler, AZ
#3
Re: RC 4.5 in lift kit.
Most "35" inch tires are not quite 35 inches.. So you should be fine for height, but your bigger concern is your width of tire. That is more likely to cause tire rub...
