Rpo Codes 1973 - 1987
RPO CODES 1973 - 1987
(Regular Production Option)
BY NO MEANS IS THIS LIST EVEN CLOSE TO COMPLETE!
AO1 - Softray Tinted Glass
AO1 - Tinted Glass All Windows
A28 - Sliding Rear Window
A31 - Power Windows
A80 - Pick Up Box Bed Rails
AN1 - Folding Seat Back
AU3 - Power Door Locks
B32 - Color Keyed Front Floor Mats
B3J -Diesel Equipment
B84 - Black Body Side Moldings (Fleetside Only)
B85 - Bright Body Side Moldings (Fleetside Only)
B93 - Door Edge Guards
B96 - Wheel Opening Moldings
C42 - Heavy Duty Front Heater (Not Available with RPO C60 A/C)
C60 - Air Conditioning
C91 - Dome Lamp
C1A -Blazer with white convertible soft top
C1B - Blazer with black convertible soft top
C1C - Blazer with blue convertible soft top
C1D - Blazer with buckskin convertible top
CD4 - Intermittent Windshield Wiper System
D44 - Painted Below Eyeline Mirrors
D45 - Stainless Steel Below Eyeline Mirrors
D73 - Pickup Box Side Rails
DF2 - Camper Style Stainless Steel Mirrors
DG4 - Extended Below Eyeline Mirrors
DG5 - Senior West Coast Style Painted Mirrors
E62 - Stepside Pick Up Box
E63 - Fleetside Pickup Box
E81 - Wood Floor Fleetside Pickup Box
F44 - Big 10 Model
F51 - Heavy Duty Shock Absorbers
F60 - Heavy Duty Front Springs (Came With HD Front & Rear Shocks Recommended For Snow Plow Use On 1/2 Ton Trucks)
G50 - Rear Heavy Duty Springs
G51 - Rear Extra Capacity Springs
G60 - Rear Main And Auxiliary Springs (30 model series only)
G80 - Locking Rear Differential
GT4 - 3.73 Rear Axle Gear Ratio
GT5 - 4.10 Rear Axle Gear Ratio
HC2 - 2.76 Rear Axle Gear Ratio
HC4 - 4.56 Rear Axle Gear Ratio
HC8 - 3.21 Rear Axle Gear Ratio
HE3 - 3.07 Rear Axle Gear Ratio
HO4 - 4.11 Rear Axle Gear Ratio
J55 - Heavy Duty Power Brakes
K22 - 94 Amp Alternator
K30 - Speed & Cruise Control
K34 - Electronic Speed Control
K43 - Poly Wrap Air Cleaner
K81 - Cold Climate Package (Including Special Insulation, 66 Amp Alternator, Special Heater & Defroster, Engine Block Heater, HD Battery.)
KC4 - Engine Oil Cooler
KO5 - 600 Watt Engine Block Heater
LE8 - 7.4 Liter V 8
LE9 - 5.0 Liter V 8
LF3 - 5.0 Liter V 8
LF4 - 400 4bbl V 8 Engine
LG9 - 305 2bbl V 8 Engine
LO5 - 5.7 Liter V 8
LS9 - 350 4bbl V 8 Engine
M15 - 3 Speed Manual Transmission
M20 - 4 Speed Manual Transmission (Chevrolet CH465)
M40 - Turbo Hydra-matic Transmission
MX0 - TH 700 Transmission
MX1 - TH 350 Transmission
N31 - Custom 16" Steering Wheel
N33 - Comfortilt Steering Wheel
N41 - NP 203 Fulltime 4wd Transfer Case
N67 - Rally Wheels (1/2 Ton Trucks Only)
N90 - Aluminum Cast Wheels
NK7 - 31 gallon Fuel Tank
NL2 - Auxiliary Fuel Tank (pick ups)
NY1 - Fuel Tank Shield
NY7 - Transfer Case Shield (Skid Plate)
P11 - Glide Out Spare Tire Carrier
P13 - Side Mounted Spare Tire Carrier (Fleetside Only)
PO1 - Bright Wheel Covers (1/2 Ton Trucks)
PA1 - Bright Metal Wheel Covers (3/4 Ton Trucks)
RO5 - Dual Rear Wheels ( 1-Ton Trucks Only)
TP2 - 3500 Watt Aux. Delco
TT5 - Halogen High Beam Headlamps
U01 - Roof Marker Lamps
U16 - Tachometer
U35 - Quartz Electric Clock
U37 - Cigarette Lighter
U58 - AM/FM Stereo Radio
U63 - AM Radio
U69 - AM/FM Pushbutton Radio
U69 - AM/FM Radio
U76 - Windshield Antenna
UA1 - Heavy Duty Battery
UF2 - Cargo Lamp
UM6 - AM/FM Stereo Radio With Seek, Scan, Stereo Cassette Player & Clock
UN3 - AM/FM Stereo Radio With Stereo Cassette Player
UY7 - Trailer Light Wiring Harness
VO1 - Heavy Duty Radiator
VO2 - Transmission Oil Cooler
V22 - Chrome grille
V31 - Chrome Front Bumper Guards
V42 - Chromed Rear Step Bumper (Fleetside Only)
V43 - Painted Rear Step Bumper
V76 - 2 Front Tow Hooks
VF1 - Chromed Rear Bumper
VR2 - Dead Weight Trailer Hitch
VR4 - Weight Distributing Trailer Hitch
X6Z - Automatic Front Locking Hubs
YE9 - Silverado Trim Package
YG1 - Custom Package (Fleetside Only) Including Bright Wheel Opening Moldings, RPO #'s B84, B96, & Bright Trim For Side Marker Lamps & Tail Lights.
YG3 - Deluxe Package Including Bright Trim For Side Marker Lamps & Tail Lights.
YG4 - Means rear seat not desired (Bonus Cab, Crew Cab, Blazer, Suburban).
YJ6 - Decor Value Package
YWF - 10 x 16.5/ Load Rating "D" Tubeless Tires
Z53 - Gauge Package (Including Voltmeter, Engine Coolant Temp, 66 Amp Alternator)
Z56 - Cold Climate Package
Z58 - Blazer white hard top
Z59 - Blazer black hard top
Z62 - Scottsdale Trim Package
Z84 - Cheyenne Trim Package
Z75 - Front Quad Shock Absorbers (Dual Shocks)
Z81 - Camper Special Chassis Equipment
Z82 - Trailering Special Package
ZQ2 - Operating Convenience Package Including AU3 Power Door Locks & A31 Power Windows
ZY1 - Solid Paint
ZY4 - Deluxe 2-Tone Paint
ZY5 - Exterior Decor Package
This is by no means a complete list. It's a good start though! There were many options offered over the years. Some of these codes were different for various years, and changed over the years too. I will be adding to this list as I get more info.
I make no claims that they are 100% accurate in every way.
Euzoa
New member
Aug 19, 2003
37
New York
#5
Re: Rpo Codes 1973 - 1987
The body style changed in 79 i believe and then again in 90 man it isnt one body style, the front clips are different
Jan 7, 2003
56
Minnesota
#7
The "bodystyle" was the same from 73-87 (88-91) as fastr68 mentioned. Yes, the front ends changed around...but so has every other vehicle that has been made for more than 1 year. Camaro's (all 4 generations), Firebirds (all four generations), Mustangs, Cuda's, Challengers, etc...all ran numerous years, while changing slightly every year...but they are still considered the same "bodystyle". :) :)
GakiAkuma
New member
Aug 22, 2006
11
ne
#8
I miss my 77c-10 Custom Deluxe. Was my first vehicle and truck.
When I move south and get some money saved iam gonna find one in rust free condition and go hog wild with it.
*runs off to cry*
#9
I have a 1978 C20, Heres the code that aren't on the list already.
These are from my SPI Sticker in the glove box:
F59 - Front Stabilizer Bar
MX1 - Auto Transmission (Means TH400 on my truck)
XPB - 750-16LT/C FRONT (7.50x16 Tires)
YPB - 750-16LT/C REAR (7.50x16 Tires)
NA2 - Standard Emission Sy (I have HD Emissions)
N41 - Power Steering (I have a 2wd C20)
ZPB - 750-16LT/C SPARE (7.50x16 Spare Tire)
17L - Saratoga Silver (Paint)
These are from my build sheet:
A52 - BENCH SEAT
D49 - STD MIRROR
JB7 - VAC PWR BRAKE
K76 - 61-AMP GENER (Alternator)
M40 - AUTO TRANS. (My build sheets says M40, but the sticker says MX1); TH400
HDX - H.D. EMISSION
P03 - CHROME H/CAPS
P10 - FM WHL CARR
V46 - CHROME F/BPR
71I - F/THORN INT T
71W - F/THORN W-VIN
YB9 - B/P INSULATOR
YG1 - U-L&W/H MLD (Upper-Lower & Wheel Housing Moulding)
z52 - FOAM SEAT
UPR - SOLID COLOR
LWR - 17 MED GRAY
Mar 3, 2010
9
East Tx
#13
the clip changed in 81, and yes, 73-87 is one body style, i can take the front clip off a 87 and put it on a 73 with no problemo, and everything will line up.....and 88 is when the body style changed
#14
This may be a dumb question, but where do I find my codes on a 73 C10. I looked in the glove box.
There should be a BIG blue and white sticker stuck to the inside of the glovebox. It may be gone, and if it is there's no way to find your RPOs unless you can find the build sheet, which might be in the bottom or back of the seat...possibly.
Glovebox Sticker...
Build Sheet - Could be anywhere under seat or carpet, in a door, etc...
