How to TEST Your Coolant for the Winter (Before Major DAMAGE is Done)
Learn how to test your antifreeze, and how to change your coolant to make sure it is protecting your car’s engine and cooling system properly. In this video I cover what how to properly test your coolant and top off your radiator so it is a 50/50 mix that way your car wont overheat and your engine block wont freeze or corrode.
Also if the heat in your car is weak or you dont have heat, in this video I will show you how to bleed the air out of the cooling system so you can get heat Coolant is 50% antifreeze and 50% distilled water. And no, freeze plugs are not going to save your engine block from freezing and cracking every time.
