Mechanics:
350ci V8 Engine (Casting Date: 1986)
Engine Components:
– *Power Steering*
– HEI Distributor
– Newer Steering Shaft
– Newer Motor Mounts
Engine Cosmetics:
– Clean and Painted Firewall
– Inner Wheel Housings Look Great
4-Barrel Holley Carb
– Vacuum Secondaries
– Electric Choke
4L80E 4-Speed Automatic Transmission
Cast Iron 205 Transfer Case
Front Leaf Spring Suspension
– Beefy Sway Bar
Rear Newer Style Leaf Spring Suspension
Stock Rear End
– Ratio: 3.73:1
– Posi Trac
Brakes:
– Front Power Disc Brakes
– Rear Power Drum Brakes
Newer Dual Exhaust w/ Factory Replacement Mufflers
New Blazer 25-Gallon Gas Tank
Body:
Frame Off Restoration (Done in 2013)
Single Stage Black Paint Finish
Hood Fits Nice w/ Fenders
Chrome and Stainless Trim Work Look Great
Door Lips and Jambs are Clean
Trunk Bed Is Clean and Straight
– Full Spare In Bed
Undercarriage Is In Great Shape
– Clean and Painted Underside
Wheels: Weld Aluminum w/ Lockouts
Tires: Goodyear Wrangler 37×12.5×16.5
Interior:
Original Black Interior:
– Door Panels Look Great
– Carpeting Is Clean
– Upholstery Is Clean
– Headliner Is Clean
Bench Seat w/ Seat Belts
Column Shifter
Floor Drive Selector
Dashboard and Dash Pad Look Great
